Washer wont fill
Error message '' de no ''
    Problem Solver:
  • 9 Answers
First make sure the power is on by plugging a lamp into the socket. Does the water flow. Can you hear trying to start to fill. If it comes in slowly the filters in the hoses may be clogged. Next check the lid safety switch some of the newer models use this as a safety use a pencil to push it down a couples of times. Hoe this solve you problem.
Posted on Jun 19, 2009
  • JWMcCormick
    JWMcCormick Jun 19, 2009
    Hope this fixes your problem
Kenmore elite washer #79641029900 wont spin or drain.Have replaced the lock switch thing on the door (was flashing de) just replaced drain pump motor
Check the drain hose and filter for restrictions also be sure the connector is plugged onto the pump motor properly. Restart the machine and check for error messages.
Oct 17, 2017 | Kenmore Washing Machines
Where is the door latch located on the LG top loader washer turbo drum model T6755pp
How to Troubleshoot a DE Code for an LG Washer ' eHow
www.ehow.com > Home & Garden
Although sometimes the only way to correct the DE error is to hire a professional to check and fix the washer, there are a few at-home troubleshooting efforts you .
Aug 05, 2015 | LG Washing Machines
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
Sw56app with DE message
On your Samsung washer, the "dE" error code typically occurs just after the rinse cycle. This will leave your machine filled with water as it does not drain because the washer thinks that the lid is open. Reset the cycle to properly drain the water then stop it before it fills up again.
Check to make sure nothing is preventing the lid switch from letting the cycle continue. Debris, such as lint or paper, could have fallen into the switch hole. Rust or an object could also block the hinges on the back of the lid. Clear anything off of the washer that may interfere with the lid switch then try to run the cycle again.
Dec 04, 2012 | Washing Machines
De error code
DE is a drain error
Check to be sure the drain filter is clear.
Nov 30, 2012 | LG WM-2277HW Front Load Washer
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
Washer will not fill . error code 'de' pulling up. whats de code?
Unfortunately you do not mention what make and model!
However 'de' seems a common indication in many washers of Door Error. Possibly either the latch or the door close sensor is malfunctioning and will require attention.
Hope this helps,
John C
Mar 02, 2011 | Washing Machines
After putting washing in the machine and setting the controls the machine fills up with water but thats all.On the display it shows the letters- de-.I would appreciate your assistance in this matter.Thank...
hello de error means this is a door lock error most of the time you would have to replace the door lock assembly this is on both lg and samsung washers if your model is another kind please message me back the make and model number and I will look further into the situation with your appliance also please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Kitchen Ranges
WASHER WONT FILL DE SHOWS ON SCREEN
its the door error the door not closing all the way.shane
Dec 19, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
