Question about Home
Keeps flashing LL - Home
The air condition button keeps flashing on and off and with it the air goes and comes
Usually means there is a problem with the system, could be low on freon or something electrical.
You'll need a shop manual to check the components.
Jul 02, 2012 | 2001 Hyundai Santa Fe
Brother printer keeps saying prepare new drum, i have installed the new drum and error keeps popping up
Hey Heather,
I've had this problem recently--what you'll need to do is press GO and + at the same time. You'll need to get it just right otherwise you'll end up pausing the machine a ton. That should take you to a list of parts, just scroll to drum kit and press 'Set' to reset it.
Aug 03, 2011 | Brother HL-6050DN Laser Printer
Hi im trying to install and get going a lexmark 1250 the paper keeps jamming i think i have that fixed but now the power light keeps flashing and both inks are filled what could be wrong with this now i...
Most of the time this can be fixed by turning off the printer on the mains supply, leaving it for about 15secs and then turning the printer back on again.
A lot of the time a flashing status light either means that there is (or was) no paper in the printer, therefore you'll need to add some and press the paper feed button. Or the paper has jammed so you need to remove the blockage and reset the printer (turn it off and back on by the mains).
Most problems can also be solved by restarting your computer.
Regards,
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
My mobile phone screen keeps flashing lg620 when i try to turn it on and wont turn all the way on nor will it turn off it just keeps flashing
Reinstall the OS ,it's also known as flashing. You'll find the details and procedure om Google
Jul 16, 2011 | Cell Phones
Im trying to use my webcam and it keeps saying i have to integrate it but i do not know how or what to do
A couple of things to try. First of all see if the drivers for the webcam are properly installed. you
should be able to go to Compaq's web site and download the drivers and install/reinstall them.
2nd thing, I have a Gateway thats similar to your Compaq and it came with no software to use the
webcam. Try downloading Skype and see it it will find the webcam. You'll have to go to the
settings on Skype and tell it you have a web cam and you want to use it.
If using an application that uses Flash like Dim Dim you'll have to allow flash to access your
webcam and soundsystem. Right click on the flash app and change the settings to allow it
to use your equipment.
May 05, 2011 | Compaq Presario CQ56-115DX Laptop
Oven keeps cutting off with a code flashing F3
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE JBP25 Electric Kitchen Range
Our 2009 Sony Bravia is flashing a standby light and keeps turning off after 1 minute. Any ideas?
u shld chek in the settin ....it might b the pblm in ur tv settin..therr ll b one signl in ur tv emot tht shows th i+ symbol click tht n go through tht ..
Mar 10, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Flash light
open your camer go to settings and click flash on
Mar 27, 2009 | Sony Ericsson K750i Cellular Phone
My thomson DTI6300-16 red light keeps flashing
There is a known power supply fault on Thomson boxes. If you go to www.satcure.co.uk you`ll be able to order the parts needed. Be aware, you`ll have to be able to use soldering irons etc. as this requires you to remove components and refit new ones.
Dec 06, 2008 | Televison & Video
Sony ericson w810i keeps flashing
i was having w810i and went and charged it after removing it it was flashing white please how can i solve this problem.From bernard
Jul 26, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Home Logo
66 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
