Question about GE WBSE2090A Top Load Washer
Washer does everything except spin - GE WBSE2090A Top Load Washer
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
How to fix the spin cycle on my Whirlpool washer?
Usually Debra you have to replace the motor when this happens motor is weak and heating up cutting out to soon ..Hope this helps
Mar 02, 2015 | Whirlpool WFC7500VW Washer
What does a ge control assembly do
The control assembly does everything except temp. on most washers it tells the washer when to fill how much to fill when to empty when to spin etc. You need a new control assembly or a different washer.
Jun 21, 2014 | General Electric WH12X10226 Control...
Hoover LA doing everything except spin
What the ??? are you talking about?
May 05, 2014 | Computers & Internet
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
this is a whirpool style direct drive. most likely coupler is broken. it's a small part, between motor and gearcase about as big around as a silver dollar but thicker. lean the washer back so you can look under it and look right behind the motor. not a major repair. worth fixing. You will want to remove the cabinet so if you decide to do it mssg back for more info.
May 24, 2009 | Roper RAX4232KQ Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
GE WBSE2090A Top Load Washer Logo
26 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
