Question about Vehicle Parts & Accessories
Change batteries accutire gauge - Vehicle Parts & Accessories
    Sergeant:
  • 191 Answers
PH1 size phillips screwdriver to remove cover, three LR44 button batteries to replace
Posted on Sep 26, 2014
Blows fi fuse
Check the injectors for short circuits. It might have been the injectors that ran the battery down to begin with.
Nov 24, 2013 | Honda cbr600rr cbr 600rr 08 09 10 11 12...
My 2006 cadillac fuel gauge suddenly stopped working and is stuck on empty any suggestions?
drop tank change sending unit,check for bad ground,bad gauge,most likely its sending unit bad
Jul 21, 2011 | 2006 Cadillac STS
98 Town Car, how do I change dash lights, (fuel gauge bulb)
  1. Disconnect the negative battery cable.
  2. Remove the instrument cluster.
  3. Remove the retaining screws for the instrument cluster lens and cover assembly. Remove the cover and lens.
  4. Remove the retaining screws for the gauge or warning lamp to be replaced and remove the gauge or warning lamp. To install:
  5. Place the gauge or warning lamp into place and tighten the retaining screws.
  6. Install the instrument cluster lens and cover assembly.
  7. Install the instrument cluster.
  8. Connect the negative battery cable.
Feb 04, 2011 | 1998 Lincoln Town Car
Is the battery for the Uwatec Aladin Tec 2G 2 Gauge Dive Computer Console - owner changeable?
Unfortunately no it is not. Although it may be possible to do this yourself what the service centre will do is pressure test the unit after battery change to ensure that the computer is still accurate at depth and water tight of course. Hope that helps
Nov 07, 2010 | Uwatec Aladin Tec 2G 2 Gauge Dive Computer...
I change the battery but the battery light still on and the battery gauge still low
Sounds like your alternator is not producing enough current. That will illuminate the battery light and show as a low voltage on the battery gauge.
Sep 22, 2010 | 1997 Ford Explorer AWD
I HAVE A 2003 TRAILBLAZER IM HAVING TROUBLE WITH THE CHARGING SYSTEM,I CHANGE THE ALTERNATOR BUT IT STILL SHOW THE BATTERY GAUGE LOW CHARGE NEED HELP ON WHAT TO DO
You need to check the voltage at the battery itself, if the battery voltage is indicating in the area of 12.5 - 14.0 volts and your dash gauge does not agree, then the dash cluster has a bad stepper motor which drives the gauge.
If the battery voltage agrees with the dash gauge, and the alternator was changed and is assumed good, you need to check the wires going to the alternator, there may a broken connection.
Sep 21, 2010 | 2004 Chevrolet TrailBlazer
Speedometer, tack, fuel gauge, temp gauge have erattic behavior
With Ign. off what is your batt.voltage reading than take neg. cable off and take another reading 5 min. later. It sounds like a intermitten short, try to isolate voltage drop when acting up. Gauge circuit would be a good start. Schematic would be helpful.
Aug 12, 2009 | 2000 Ford Windstar
Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
Aug 06, 2008 | 1994 Oldsmobile Cutlass Supreme
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
