Question about Samsung RS265TDRS Side by Side Refrigerator
Refrigerator is not cooling
The freezer is working properly, but the refrigerator is not cooling.
5 Suggested Answers
SOURCE: Refrigerator not cooling properly
This site has a solution. And it's a well known problem with Samsung's refrigerators. Basically the evaporator behind the panels inside the fridge (not the freezer) is iced up. If you open the panel and let it thaw, it will fix the problem. However in my case, the same old problem comes back in 20 days. I'm trying to find a long lasting solution instead of putting a band-aid on the issue.
Posted on Aug 02, 2008
MNTECH
  • 1543 Answers
SOURCE: The digital display resets to 0 F for BOTH the
The OF OF display is the OFF setting, used for display purposes, so the light and controls light, but the refrigerator does not run while it is on display at a dealer. Try pushing in and holding the top two buttons on the left side of the display for about 5 seconds at the same time to get it out of the display mode. You should be able to set temps then.
Posted on Jun 20, 2010
Testimonial: "Thank you MNTECH, that seems to have worked. (I have it on power freeze and power cool now to quickly return to the proper temps) Background: We had family & friends over using it for ice & cold water and one person unfamiliar with the feature was tapping the buttons. She must have hit the sequence to send it into "display" mode as you correctly surmised. Will check the frig in 20min to see if it is getting cold again. But I think that was it. (The display does now read -4F and 34F which are the temps I typically have it set at)"
heatman101
  • 43501 Answers
SOURCE: The freezer (top) is working
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 10, 2010
SOURCE: the refrigerator is not getting
If youre freezers making ice, and the ice remains dry, there is nothing wrong with the refrigeration cycle or components, the issue is merely insufficient airflow from the freezer into the refrigerators box.
The reefer box is 100% reliant upon the freezer for all of its cooling capacity the reefer section is a byproduct of the freezer, only the freezer has an evaporator coil, there is a small duct between the two sides, the freezer box and reefer box and a movable flapper door/damper that allows or disallows the freezers cold air to migrate into the refrigerators section.
This is a huge and common issue as evidenced by the numerous examples posted here saying, My freezers fine, but reefers warm!!! Impossible actually, unless the damper door that modulates the freezers airflow into the reefers box is closed down, not allowing enough freezer air into the reefers box.
Now when one sets a temp on a reefer the thermostat with the 1=10 and off setting that will cyle the unit off is the 1st place we go, and we raise the setting to cooler temp desired, or max it out most commonly as more is better?? NOT! Sure its fine to peg, max or increase the thermostats setting to the coldest seting, if you want a colder reefer box.
However where the counter intuitive labeling of the remaining dial or setting is where everyone messes up and actually exascerbates the warm reefer box isssue they discovered and attemptef to rectify by peggimg, maxing or at least raising the coldness desired .
The remaining setting has no electrical circuits and cycles no compressor or fan or anything except closing or opening the door that seperates the freezer box and reefers box
If you will notice the writing carefully it says cooler and warmer, or colder warmer etc.
The logical thing to do and waht 99% do when they suspect the reefers warm is raise both, or max both, which males for a colder freezer temp not the reefer! if the dampers ets at max or coldest is shut odff to the reefers box, allowing for a colder freezer as was stsated on the dial only thing is its for the wrong box!! If the freeezers ok and making ice that is dry the setting for airflows off or broken or damper doors stuck obstructed, I cant telll you how many times i billed $85 bucks to set the damper in the middle setting whrre all the dials should be anyways!!!
Posted on Dec 27, 2010
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Can get my fridge freezer off the vacation button
This is list of refrigerator problems,which is normally faced in refrigerator.
You can go through the details,by clicking the link below:---
Dec 22, 2012 | Refrigerators
Freezer not working
Check the help links shown below :----Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html-----------Both refrigerator and freezer not cooling properly in refrigerator?
This willhelp.
Thanks.
Feb 10, 2012 | Maytag MBR2256KES / MBL2256KES
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
The freezer works properly, but refrig part does not cool to proper temperature. Have checked doors and cleaned behind.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Estate Refrigerators
Freezer is working fine but the upper area refrigerator is not cooling properly. Temperature is barly cool but not cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Samsung RS265TDRS Side by Side Refrigerator Logo
26 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
