Question about La Cafetiere Santos SN030200 3-Cup Coffee Maker
How do you make coffee in cafetiere 6 cups - La Cafetiere Santos SN030200 3-Cup Coffee Maker
    President:
  • 1,185 Answers
You grind the beans quite fine
Pull up the knob on the lid till it pulls out of the top and the filter out of the glass container.
Put enough of the the ground coffee for six cups into the glass container , pour on boiling water till it reaches about one inch from the top
Put the top back on a push the knob slightly down to locate it in the top of the glass container
Give the water a few minutes to work on the beans and then gently push the knob all the way down so that the filter goes to the bottom og the glass container taking the grounds with it
Pour the coffee
Enjoy!!
Posted on Jun 19, 2009
How to measure coffee for 45 cups. Also is a filter needed.
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
100-CUP MODEL #33600
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
Mar 09, 2011 | West Bend 33600 Coffee Maker
How much coffee do i add into a Hamilton Beach 48274 Brew Station 6-Cup
You may add 6 tsp of coffee powder or two coffee beans if u have a grinder
thanks
May 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
Weak coffee is the result of brew
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 17, 2009 | Regal Ware 58001R
Since it is "brand new out of the box" check for plastic burs (pieces of plastic improperly hanging around
openings along flow of water) throughout unit, and use more coffee than recommended for your taste of
what a good cup of coffee should taste like, since that varies from individual to individual. If you are using
packets, try using TWO. Experiment, Experiment...........
Apr 17, 2009 | Regal Ware 15-0264 Polished Aluminum...
Faberware Superfast FCP412 makes weak coffee
check the bottom of the tube that holds the coffee basket....there is a "washer like" piece on the bottom. Make sure it is clean and moves freely, or the coffee won't percolate properly. I had the same problem and that fixed it
Mar 30, 2009 | Faberware FCP412 Coffee Maker
Doesn't heat the water
Jan 27, 2009 | Nespresso C100B Essenza Single-Serve...
Won't perk properly
Oct 21, 2008 | West Bend 13500 Coffee Maker
Amount of coffee to use
This is from the FAQ section of West Bend's website at www.focuselectrics.com:
As a guideline, use the following amounts of ground coffee for the number of cups being prepared. Use standard measuring cups ( as used to measure flour, sugar, etc.) to measure the coffee. The amounts of coffee below will brew mild to medium strength coffee which most people prefer. The amount of coffee can be adjusted to suit personal preference. As a guide, there are about 5 cups of coffee to a pound (16 ounces).
  • 12 - 18 Cups Coffee = 1 - 1 1/4 Cups Grounds
  • 20 - 25 Cups Coffee = 1 1/4 - 1 1/2 Cups Grounds
  • 28 - 36 Cups Coffee = 1 1/2 - 2 Cups Grounds
  • 40 - 45 Cups Coffee = 2 - 2 1/2 Cups Grounds
  • 50 - 60 Cups Coffee = 3 - 4 Cups Grounds
  • 70 - 80 Cups Coffee = 4 1/2 - 5 Cups Grounds
  • 90 - 100 Cups Coffee = 5 1/2 - 6 1/4 Cups Grounds
  • Hope this helps. You might also be able to download the manual from there if you look for your model.
    Sep 23, 2008 | West Bend 13500 Coffee Maker
    La Cafetiere Santos SN030200 3-Cup Coffee Maker Logo
    261 people viewed this question
    Top La Cafetiere Coffee Makers & Espresso Machines Experts
    Marvin
    Marvin
    Colin Stickland
    Colin Stickland
    Kolbrun...
    Are you a La Cafetiere Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
