Question about Lorex Home Security
Black screen web camera
One of my wireless cameras has been working fine for a long time now but suddenly it went to a black screen on its part of the monitor. I do not think the camera is broken but what could cause this.
  • 2,760 Answers
COULD POWER TO THAT CAMMERA BEEN CUT OFF ?
QUICK TEST AT NITE LOOK CLOSELY AT CAMMERA LENS SEE IF YOU SEE A LIGHT PINK/RED TINT TO IT, no THEN POWER IS OFF OR UNIT IS DEFECTIVE
Posted on Dec 05, 2014
5 Suggested Answers
SOURCE: wiring installation for back up camera monitor
yes the black is ground, the red goes to a constant power in the fuse block , and the blue goes to the reverse wire to activate the monitor
Posted on Jun 08, 2009
paulrelliott
  • 69 Answers
SOURCE: Channel 3/Camera 3 not displaying properly
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
Posted on Sep 22, 2009
cbinny1
  • 64 Answers
SOURCE: on the monitor there is a small little camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is not coming from the camera...They don't put anything like that out. Check the OSD settings of the device the video is going into. If there is On Screen Display setting with in the device (DVR, MUX, Matrix Switch, ECT)....if that doesn’t work then check the monitor menu to see if its a display feature you can turn off...good luck and let me know if this helps just remember the pelco camera will not push any graphic out except in the case of a PTZ where you will see the Protocol information text...
Posted on Oct 22, 2009
  • 1116 Answers
SOURCE: I have a Voyager Model
It is possible the monitor burned out. The fact your have power to the unit more or less confirms that. You can check by taking any other TV (which for all intent and purpose) is a monitor and connect it to the outputs. If the TV produces a picture, your monitor has seen it life end. More times than not the units life is not going to be like that of a normal monitor, as it has a constant flux in power ranging from 9VDC to 13.5VDC. This can take its toll on diodes and capacitors, as well as power supplies.
Posted on Jul 08, 2011
Samsung st150f
Take battery out and wait 15 minutes and reinstall and charge without turning on the camera, works for me.
Apr 24, 2014 | Samsung Cameras
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Black screen on playback dcr pc 105e
Can be the Drum/Video head that is faulty or the flexy cable between the lcd and the main pcb
Nov 10, 2011 | Sony Handycam DCR-PC105E Mini DV Digital...
Black screen; lens won't shut; totally not working now
Sound like the sensor or recoding electronics are bad. The camera is most likely beyond economical repair and I would buy a new one.
Nov 19, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Acer aspire 5735 crystal eye web cam not working
install original driver for camera and update your windows.
May 31, 2009 | Acer Aspire 5735 Notebook
Macbook Camera stopped working when abroad
reinstall again the webcam driver.
maybe it works
May 19, 2009 | Microsoft LifeCam VX-3000 Web Camera
SUPER DARK SCREEN, BLACK PICTURES
I have seen this several time the lens cable can cause this issue it could also be the back light or the LCD I repair these all the time If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
Oct 02, 2008 | Casio Exilim EXZ75 Digital Camera
LED display on powershot a630 is very dark. It was working fine, and then when I moved the display it suddenly went dark
pershaps that the cable inside to power the lcd is defect. or it could also be that the backlight is defect . those things can be repaired (don't do it your self) but costs could well be higher than buying a new camera
Mar 22, 2008 | Canon PowerShot A520 Digital Camera
Polaroid i532 black screen and red to green light
I have the same problem with mine! I haven't been able to find any information on the web about a solution yet. Just a lot of frustrated camera owners!
Sep 18, 2007 | Polaroid i532 Digital Camera
Screen is black
This suggests the back light has failed. Depends on the age of the camera -if recent purchase and under warranty send it back to the seller. A reapir I would think for an older camera would be expensive - a new camers is a better bet
Aug 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Home Security Logo
137 people viewed this question
Top Lorex Home Security Experts
Lawrence Oravetz
gbob59
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
