Question about Sewing Machines
I need a manual for sigma 2000ns supermatic - Sewing Machines
My double discs no longer work on me Elan Supermatic sewing machine
Are you sure you have the settings right on the machine? It can be a little unintuitive with these old Swiss beauties. Start by checking the disc is fully clicked into the Elnagraph, there is a little finger underneath which marries up with a hole in the disc. Now turn the dial in front of the elnagraph to A, the automatic setting. Now turn the stitch length dial to the straight line and the stitch width to A also.
There were a few variants of the supermatic and I have descibed the last one the Star Series, this machine is white with blue top. But I have got a manual for the earlier green supermatic as well so could drag this out if you havent resolved the problem. I do find that any machine left for a while unused may,suffer from loss of needle swing, the needle bar bearing gets funked up. Can be worked loose with Triflow and gentle wiggling. The bar bearing slides across on a shiny metal rod and is,pulled back to centre by a spring, so,this could also have broken,or come off.
Sep 25, 2014 | Elna Sewing Machines
How do I turn the selection dial to zigzag on my Elna Super
I've got a Supermatic manual but I think maybe you mean the earlier model perhaps. On the supermatic you set the stitch width to 2 and stitch lenth to 2+ for a zig zag. In this image, the stitch width selector is marked "3" and the stitch length selector is marked "4".
I've got a feeling that on the earlier model you may need to use a zig zag (single) disc in the Elnagraph to get the needle swing function.
As you probably don't have a manual, you may want to join the Yahoo group called Elna Heirlooms as the members there share info on these vintage machines, and some manuals are there.
Go to www.yahoo.com, sign up, then go to "Groups" and search for "elna Heirlooms". You will need to ask the moderator to join the group but once accepted, you'll find lots of helpful information, check out "Files" for shared documents.
Hope this is of help to you.
Nov 06, 2011 | Elna 2007 Mechanical Sewing Machine
Where to get a user manual for Elna Supermatic 722010 sewing machine - vintage 1963-1964
Hi Beverly,
My suggestion is that you join up the Yahoo group called "Elna Heirlooms" you'll find lots of very helpful fellow supermatic owners there and probably what you are looking for too. Here is one page from the manual for threading the bobbin into tension, once you've mastered this on the Elnas, its the same for all the Swiss ones.
Yes, top threading is important, you need to get the thread into the tension discs and also the take up lever. Have you cleaned out the tension discs too? these do get gummed up with fibres and dye particles sometimes. Just turn tension down to zero and "floss" between discs with the selvage edge of a clean piece of waste cotton fabric.
Might see you over on Yahoo, several of the members there are really knowledgeable on these great machines.
cheers
Tallygirl
Oct 13, 2011 | Elna 2007 Mechanical Sewing Machine
I have lost my manual for my elna supermatic seger, where can I find one?
Hi Glen, not sure if you mean sewer, or serger. The Elna Supermatic sewing machine manual is available at this link: http://www.clawges.com/sewing/Elna_manual/index.html
Trust this is what you are looking for.
Sep 01, 2011 | Sewing Machines
I HAVE A ELNA SEWING MACHINE MANUAL AND CAMS AND FOOTS TO FIT OF ELNA SEWING MACHINE BOUGHT 52 YEARS AGO UNFORTUNATLEY I DO NOT HAVE THE SEWING MACHINE I LEFT THAT WITH A REPAIRER HERE IN ADELAIDE AS IT...
I would love to take these off your hands as my Mum has an Elna Supermatic that was her mum's. Could you email me on cwrogers@tpg.com.au, I'd be happy to pay postage to ship, I'm up on the Gold Coast.
thanks
Carolyn
Mar 17, 2011 | Elna Sewing Machines
The feed isn't working on my Elna
I'd suggest that you join the Yahoo user group for Heirloom Elnas, the members are very helpful and share images of manuals and their experience. You should be able to download a copy of the supermatic manual from here once you've joined up.
Is your supermatic a green model like this one?
or there is a white with blue top supermatic from the Star Series, it looks like this
If its the star series, you'll see above a round knob with red and black numbers, this is the stitch length dial. Red is reverse, black is forwards. The lever just to the left is the stitch width lever and the round dial to left again is the needle position dial.
If its the green model then the dials and knobs are in different places but they work in a similar fashion.
Good luck wiht your machine.l
Mar 04, 2010 | Elna 1010
I was given an Elna Supermatic 722010 and am not sure how to wind the bobbin.
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Oct 21, 2009 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
