Question about Brother HL 1440 Laser Printer
Forms stuck on roller
I put through a peel apart form and the paper separated allowing the adhesive to stick on the roller that is visible from the back of the printer. This created quite a mess. I was able to pull most of the paper out with a tweezer but some remains on the roller. How can the roller be removed?
  • Brother Master
  • 1,113 Answers
Not simply, Remove from mains, all covers must come off first, then it is obvious. Probably will need new fuser
forms stuck on roller - 2d9596b.jpg INFO
Ensure labels are laser type and paper type is set accordingly
Posted on Dec 30, 2007
How to separate the film form the backing
What format film are you using ? If it is 120, 127 or 620, then the paper backing is held on at one end with adhesive tape.
Sep 18, 2017 | Photography
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
How do I smooth old flooring adhesive enough to put new floor tiles on it
Depending on the size of the room you should use a floor sander or a buffer with a abrasive pad to smooth the serface to your liking
Mar 11, 2014 | Building Materials
Hp laserjet 4 plus label stuck and prints with smudge now
Where is the label stuck? If you are lucky and it is stuck on the toner cartridge's image drum, just replace the toner cartridge. Do not, I repeat, do not try to remove the label from the drum and continue to use the toner cartridge. The reason being that there will still be adhesive on the drum that will cause toner to stick to it and cause big bad defects on the printed page. Additionally, if you try to remove the adhesive with lighter fluid, rubbing alcohol, or other substance and a cloth/paper towel, the drum will be scratched and therefore damaged, causing defects in the printing anyway. Just save the trouble and replace the toner cartridge.
If the label is stuck elsewhere within the printer, be very careful about removing it, especially pay attention to whether any adhesive stays behind once the label is removed. Depending on where the label is, it might just be better to replace the labelled part.
It is highly recommended not to use labels inside laser printer precisely because of this problem. If you elect to do so, however, make sure that you use only laser labels. Inkjet and dot matrix (aka impact printer) labels are unacceptable. The reason being that laser printers generate about 350 Fahrenheit degrees (177 Celsius degrees) of heat which weakens the bond between the wax paper and the adhesive of the label. This causes the label to have a tendency to peel off in the fusing assembly and/or output rollers. Also the printer has a very "curvy" paper path and all that flexing of the paper tends to cause the label to want to leave the wax paper backing as well. All it takes is a loose edge of the label to find even the slightest surface to which to adhere and the deed is done: the label will leave the paper and become a part of your printer, giving you the headaches that you now endure. If you have a future need to print labels, I would suggest doing so with either a dot matrix or inkjet printer.
Feb 07, 2013 | HP LaserJet 4 plus Printer
Canon Pixma MP160 not feeding paper properly. there is no jam or anything blocking. It grasps the paper but wont feed it thru and the computer will tell me its out of paper
It sounds like a dirty or broken paper sensor. Look in and around the paper tray feed mechanism to see if there is a lever or something that touches the paper (possibly very small). That "lever" has another end to it that usually goes between two optical sensor elements, and acts as an interrupter between the sensor pair when the paper is either empty or full (I'm not familiar with your particular printer). The sensor pair may be part of a plastic assembly, and the only indication that they are sensors are that the inside surfaces are usually shiny (when clean), and that you have a lever or something that goes in between them. You may also see some wires going to either of the sensor pair or plastic assembly that they are part of.
If that little lever is broken, your boned. Otherwise the optical sensors may just be dirty. If so, you may be able to clean them with a dry Q-tip (be careful NOT to break that lever). If you can't reach in there with a Q-tip, you might try a can of compressed air pointed at them to clean them off (an air compressor will work, but make sure it's not spitting out any water with that air first).
If you think your having problems because the rubber rollers on the paper pickup are really dirty (can't grab & feed the paper properly), here is a trick I developed years ago. You'll need a couple of pieces of heavy card stock (110+LB), and a can a Duro Brand adhesive spray (DO NOT use 3M-Super 77). You spray a VERY light coating of the adhesive onto all but the top three (3) inches of one side of the card stock (use a piece of cardboard as a mask). Let the adhesive set for 10 minutes (should stick and peel off like a post-it note). Feed the card stock into the printer (3 inch non adhesive end first) by hand while pressing the page feed button on the printer. The adhesive will grab any/all dust/**** inside the printer and rollers, making them look/act like new. You may need to do it more than once (use a new adhesive sheet each time). Run 3 or 4 "UN-COATED" sheets of that same card stock through to clean up any excess adhesive that may still be on rollers. CAUTION: If you insert the card stock in backwards (adhesive coated end first), or you don't leave at least 3 inches on the leading edge un-coated, or if you run regular (thin) paper through it without getting all the excess adhesive off the rollers first, the paper WILL wrap around the rollers and you WILL have a mess on your hands.
Let me know if any of this helped.
Jun 16, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Paper pickup fails causing "paper jam"
If youcan get to the rollers and clean them with an alcohol solution, then this will cut the glaze that forms on the rollers from the talc use to keep the paper separated into sheets. That glaze coats the rollers and prevents the suction action of the neoprene to pick up paper.
Feb 03, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
PAPER FEED WILL NOT FEED MULTI PART FORMS
Look for an adjustment that allows thicker paper/multipart forms to fit around the roller. Usually a click stop type slide near the roller.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
Printer tray mispick
need to buy a "paper separation pad kit" once you get the new pad,remove the toner cartridge and with a long phillips screwdriver remove two screws that holds the paper feed roller,remove the roller and now you have a full view of the separation pad,with a little flat screwdriver PEEL the rubber from both separation pads the old inside the printer and the new one you just got,put the new rubber sep pad in the printer and put the paper feed roller back.....printer will work as new again....
Jul 29, 2009 | HP LaserJet 3200 All-In-One Printer
Printing multi copy forms
you can check your paper size or the tear of poit and set it to that point.
Oct 01, 2008 | Epson FX 890 Matrix Printer
Brother HL 1440 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
