Question about Sub-Zero 695/O Side by Side Refrigerator
How to replace water filter on sub zero 695
Need to find where the water filter is located on sub zero 695
Krazytech
  • 725 Answers
SOURCE: Water dispenser conditnues to drip after releasing the button
No seal or gasket on the water line... you do have a water valve that maybe sticking open .... and/or the switch in the water dispenser is stayng open...hope it helps let me know..
Posted on Jul 22, 2008
  • 56 Answers
SOURCE: Sub-Zero 680 - Service light flashing/need to change the filter
The service flashing means that you had a long run time over a period of time. You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that will clear the fault code. If it comes back you have a problem that needs to be addressed such as cleaining the condensor. There is no factory filter on these units. If there is a filter it is most likely under the unit, which can be accessed by removing the kick. THe kick plate is held in place by two phillips head screws, remove them and have a look. If it was done by a "professional" they should have put an inline shut off valve for easy replacement of the filter.
Posted on Dec 06, 2008
SOURCE: sub zero 695 freezer not freezing.
There are a couple of possible problems. If you mean load motor noise as in the compressor then you likely have a sealed system problem. Either a bad internal valve is making it noisy and you are loosing presure within the system. You will need a new compressor if this is the problem. A technician could tell you if this is the problem just by checking the internal low side presures. A few things that I would check before calling a technician is 1. Make sure the condenser fan in the upper unit is running. 2. Check to see that the internal fan in the freezer is operating as well. 3. Check to see that the freezer light is going off when you close the door. If all of these things are working I would suggest call a technician.
Posted on Mar 23, 2009
  • 531 Answers
SOURCE: My Sub Zero 695 refrigerator seems to be running most of the time
check your coldcontrol see if to high
Posted on Apr 07, 2009
  • 31 Answers
SOURCE: Need to change the water filter on my Sub Zero
Hello. The factory indicates your unit required an in-line water filter if your plans were to use one, or the installers added it. There was no indication of an internal filter in the fridge itself. If there was it should be easy to see or find. However this can be good news for you also as your filter (if installed) migt be easy to find and access behind or near the fridge if installed well and a good quality but common form of water filter you can easily replace may have been used, if installed. Otherwise if you have whole-house water filtering already they may not have added any further filtering.
If you can contact who installed your 690 they should be able to tell you where they installed it and what type. If not just have someone follow your water line to the fridge unit, and see what turns up as you make your way along to the place where water connects to the fridge.
http://www.subzero.com/resources/products/downloads/600installguide.pdf
Posted on Oct 23, 2009
Need owners manual for a Sub-Zero 695 and maintenance manual
If your trying to remove the grill plate thats located at the top of the machine what you need to do is open both the freezer and the refridgerator doors and look up. There are three vertical phillips head screws that you'll need to remove first. After that you'll be able to pull the grate forward and remove the springs, one on each side that keeps tension on the grate. Once those are removed, the grate will be easy to take off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 26, 2012 | Sub-Zero 695/S Side by Side Refrigerator
The ice maker in my sub zero 695 is not working, what may be the problem? and where can I buy the bulb for the lcd indicator?
NORMALY ITS THE INLET VALVE THE WAY I CHECK A VALVE IS HOOK 110 VOLTS DIR TO IT IF WATER COMES IN IM THE IM MAKER ITSELF IS BAD
Nov 06, 2009 | Sub-Zero 690 Side by Side Refrigerator
My sub-zero 695 motor keeps running, very noisy..
If it is one with the compressor on top . Check the coils up top . You may find that they need cleaning because it sound like it's unable to cool enough to satisfy the thermostat therefore it runs all the time trying to.
Please rate solution
Aug 25, 2009 | Sub-Zero 695/S Side by Side Refrigerator
No water for my sub zero ice maker system 532
Check in two places either behind the fridge or under the cabnit where the water supply is. If not there then check up underneath th back of the fridge
Feb 14, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Unlock water
you have inadvertently activated the button lock- keep children and other hooligans from playing with the buttons. :)
Hold down the light button until the red key is no longer lit.
Oct 08, 2008 | Sub-Zero 695/O Side by Side Refrigerator
SUBZERO 695
try this... the water valve in your sub. is located in the upper part. ( close to the condenser fan motor. yes the new one.) tell your TECH to test the water dispenser and by pass the ice maker. the leak is on top part . running all the way dow. good luck.............................LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU.... THANKS
Jul 29, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Jul 22, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Water/Ice Dispenser Does Not Consistently Work
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero 695/O Side by Side Refrigerator Logo
396 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
