Question about Car Audio & Video
Does a parrot have a seperate fuse - Car Audio & Video
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
The parrot does not display the good bye message when i turn the ingition off the man at halfords said he does not know why but the book says it must display that does any one know why?
the ign wire and the positive wire need to be switched around. on the parrot loom there is a red wire and a yellow wire with in line fuse holders, switch them around, ie red to yellow and yellow to red
Jun 25, 2011 | Parrot GPS
Hi Guys had a parrot with LCD display for a few years now when I start the engine it does not boot up, normally if you have the phone with you it will prompt you to connect if you dont have the phone with...
The software has crashed. You can try pulling the fuse for the parrot and it may boot back up but i would do a software update if you have had it a few years. Make sure the kit says 'goodbye' when powering off, if not then it is wired wrong. Parrot web site has a list of certified installers.
Feb 21, 2011 | Parrot Hands-Free Car Kit with LCD Display...
My hands free parrot in my car went out in the middle of a call and has not worked since. Don't have a clue where to start top find out whats wrong
Is there anything on the display or is it a dead Parrot?. Does it make any noises?. If there is not life at all them you will need to find the main blue box behind the dashboard and check the fuses, normally behind the radio. otherwise go to parrot web site and contact one of their certified installers.
Jan 10, 2011 | Parrot CAR PAICK3300 GPS Receiver
Trying to fit Parrot MKi9200 to 2008 vivaro but screen blank
check there is an ignition supply, newer vivaro's did not have an ignition supply at the radio and you will have to run a wire from the parrot to the fuse box at the end of the dashboard, this will be yellow wire. If you are in doubt contact a parrot engineer from parrot.com
Jun 12, 2010 | Parrot Mk6000 Bluetooth Hands Free Kit
Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Feb 11, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Just fitted parrot mki 9200 into a vito van and nothing happened how do you switch it on
You need to add a ignition wire, the vito uses the can bus to turn the radio on. The glove box light is on an ignition. also you may need to change over the perm live and the ignition wire on the parrot iso loom. you can do this at the fuses.
Aug 19, 2009 | Parrot Cell Phones
3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot Car Kit "no signal" detected problem
I have had the same problem and the only solution I have found thus far is removing the fuse supplying power to the radio(assuming this is where the parrot is getting power from) for some time.
Jul 02, 2008 | Parrot CAR PAICK3300 GPS Receiver
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
