Question about Vehicle Parts & Accessories
2000 peterbilt 378
Replaced starter...now when started voltmeter shows 12 instead of 14...and when you turn lights on...radio goes off and voltmeter drops to 10..
  • 53 Answers
Sounds like the Alternator is NOT working.
Get it checked by an Auto-Electrician.
Posted on Apr 21, 2014
Peterbilt 378. Where is the orifice tube located?
Call the dealer they assist u free of charge.
Jun 24, 2015 | AC Cars & Trucks
2004 378 Peterbilt,low beams on but high beams also on faintly
Usually mean there's a bad earth. Most automotive electrical problems stem from poor earths.
Mar 23, 2015 | Cars & Trucks
My 2003 Saab 9-5 Aero 4-cyl Turbo Won't start. However, I have power in car, lights windows and radio works. But it won't turn-over. It could be Starter or Starter Relay. I can't find out
Ok, those systems might still work because the not require as much energy as the starter. Check the Battery Voltage with a good Voltmeter. If below 12, there might be your problem!
Mar 26, 2013 | 2002 Saab 9-5
Hi I have a 2005 peterbilt 379. I have replaced battarys and alternator and it show it charging good as soon as I turn on my head lightsthe volts go down 12 on my gauge when I hit a bump its back to 14...
Depending on the output of your alternator, and the rpm range of your idle. will determine how much and how fast the alternator works to charge your batteries.
as well as having inverters attached to your batteries that draw juice from these batteries as well as your lights.
look into adding or changing your trailer or marking lights to LED it will help on the draw from your electrical system.
Aug 31, 2011 | 2000 Chevrolet 3500
My mom has the same problem w battery w. chrysler 300m(2002) she allready replace w. new battey then chrysler service dept. told her the battery was fine n replace her starter now electric shop says it is...
Sounds like alternator if the battery is not staying charged or the output from alternator the big red wire is lost connection to battery +.
a voltmeter you can check with across battery and it should show minimum 13.8 volts minimum to be charging.
if the battery is low it should show 14.7 volts if it shows 12 volts or less with lights heater etc running then alternator is not charging.
You can get a cheap volt ohm meter from radio shack or walmart and use the DC setting 20 volt scale on meter and start the car and turn on everything and put the test leads of meter across battery terminals and see what the voltmeter says.
May 18, 2011 | Chrysler 300M Cars & Trucks
Car will not start, put a replacement starter on that had been re-built on Monday, on Wednesday the car did the same thing. The lights, electric windows, radio etc will paly but car will not tun over. Can...
Do you hear a fairly loud 'click' when you try to start? That should be the solenoid for the starter that is trying to work. You need a test light or voltmeter to check what is happening to the starter itself. When the solenoid clicks, it is pulling a very heavy electrical contact closed which applies 12 volt power to the starter motor. Check the large terminal on the solenoid that has the + battery cable attached--the test light should light before and during any attempt to start (the meter should indicate 12 volts). If the light goes out during the start attempt, clean the battery terminals and check the condition of both cables. If still no start, test the starter side terminal of the solenoid--the light should come on only when start is attempted. If it does, the starter is bad. If you get no light at all, the solenoid is bad. If the battery negative cable is connected to the car body, check for a broken or loose cable that runs from the car body over to the engine. Hope this helps!
Apr 16, 2010 | 1999 Honda Civic
2008 Hummer occasionally will not start. Completely randon when this occurs. Can sometimes wait a few minutes and it starts and sometimes much longer. This has basically been happenning since new. Dealer...
Do you hear a clicking sound around the engine when it doesn't start? Have someone try the starter while you listen carefully under the hood for the source of the clicking. If it comes from the starter/solenoid area, you will need a voltmeter or test light to test for 12 volts at the battery side of the solenoid (light on or 12 volts always while attempting to start). If light goes out (12 volts goes to zero), then replace the positive battery cable that connects at the solenoid. Next test is at the solenoid other heavy terminal that connects directly to the starter motor. If the light never goes on (12 volts never appear) during start, the solenoid is bad and should be replaced. If light comes on (12 volts appears), then the starter motor is bad and should be replaced. (It likely has a dead spot in the commutator.)
Sep 08, 2009 | 2008 Hummer H3
2000 trooper wont start!!! pulled it in the driveway shut it off then wen't to leave and wouldn't start. i changed the starter relay and still nothing. makes a clicking noise and that is it. is there a...
Sounds like the starter solenoid is working, but the starter motor isn't. If you have a voltmeter or test light, measure for light/12 volts at the motor terminal while someone tries the key. If the solenoid is what is 'clicking', but nothing at the motor terminal, change the solenoid. If you get light/12 volts, then the motor itself is in trouble.
Aug 22, 2009 | 2000 Isuzu Trooper
O4 armada wont start. battery good terminals
sounds like the terminals at the starter may be bad. thats the sounds you would normally get from a dead battery, but if the batt and terminals are good then check the connection at the starter. if the connection at the starter is good then you probably need a new starter.
Aug 06, 2009 | 2004 Nissan Armada
Vehicle Parts & Accessories Logo
63 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
