Question about Car Audio & Video
Parrot bluetooth manual
Does not switch on
Got a car with ck 3100 parrot fitted and can't get it to work with nokia c 5 as no instructions came with it
http://www.parrot.com/fr/support/guidesutilisateur/parrot-ck3100_user-guide_en-fr-es-de-it-nl-pr.pdf
Above is a link to the instruction manual. Try deleting any old phones from the paired devices menu, this way it should make room for new pairings. If this fails then you may need new software in the Parrot. You can do this yourself but you will need a Laptop with Bluetooth, then download the update manger from Parrot web site.
Dan
Nov 07, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Will not connect to my sonyericsson w995
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone:
* Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE
* Phone will search for available bluetooth devices
* Select Parrot Product from the list
* Enter Passcode "1234" and go to OK
* Accept the pop-up
* Devices are now paired and connected
fleche.gifSending contacts via Bluetooth
Jan 29, 2011 | Parrot Hands-Free Car Kit with LCD Display...
My Parrot CK3100 will not seem to switch off when the ignition is turned off and the car is locked. The display seems to remain on 24x7 and now seems to be draining the car's battery. Any idea how to...
Hi there, my Parrot CK3100 screen just says "Goodbye" how do I switch it back to the Parrot symbol, so I can pair it up to my Samsung Wave via bluetooth. My phone is connected to the device, but the divice is not connecting to my phone?
Jan 24, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Describe your How to connect Nokia E71 to Parrot car hands free kit.
On Nokia switch on Bluetooth. Then switch on Parrot and set it to pairing mode(you didn't specified your model so can't go further). Then on Nokia press under Option Pair new device? and let it find Parrot. When connection made it will ask you for paasword(usually 0000 or 1111,but may be different-see manual). Both codes must be the same. Then save and enable automatic pairing. Done.
Oct 15, 2009 | Nokia E71 Smartphone
Problem updating Parrot LS-GPS
The Parrot manual states that the software update can be conducted via bluetooth (BT). I've managed to get BT connectivity both the laptop recognising the Parrot as a headset, and indeed it cts a PC speaker in the mode, and also from the Parrot linking to the laptop. But wehn using the Parrot Software update tool, and attempting to connect via BT, non of the displayed COM channels work. Authentication fails. The laptopn connection also only stays up for about a minute. Confusingly the Parrot also offers an update item in one of its menues, and supplies a 4 digit passowrd, but I can't see how this can be used. Any ideas?
Sep 14, 2009 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
No intruction manual
hi
kindly download the user manual from the below link....
http://www.parrot.com/usa/support/userguides/parrotminikit
thank you
have a nice day
May 07, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
New phone needs to be connected to my Parrot
You will need to go to settings and paired devices, delete any old devices, then go to settings / advanced settings / pair with phone. this will then give you a pin code to enter. Now search from your phone for Bluetooth devices, select parrot and enter the code given.
you can find a manual at parrot.com
Dec 22, 2008 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
Parrot CK3100 Bluetooth Phone Kit
how do I clear full memory from parrot blue tooth phone system
Jun 20, 2008 | Parrot Hands-Free Car Kit with LCD Display...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
