Question about Car Audio & Video
I have a Jl audio W7 13.5 AE sub, and i want to wire it in parallel to my Rockford Fosgate T1000-1bdcp amp, can that be done?
  • 14 Answers
SOURCE: Car Sub JL 12w3 low sound
So I am assuming that you have just setup/wired this up recently? Have you had this working before?
You can have a look at the gain control on the amp & see if this have been set really low. This will help if the signal coming from your stereo is weak. The other thing I would suggest is to make sure that the amp can actually push this sub. I know what the specs say:
  • 1 channel audio amplifier
  • 1 x 350W RMS @ 1.0% THD
  • ThermalThrote full-on power assurance
  • 2 ohms stable (non-bridged mode only)
  • RCA type inputs
  • 0.3-6.0 VRMS input capability
  • Continuously variable High-Pass & Low Pass 50-250 Hz
  • Continuously variable Bass Boost settings (0 tp +12dB)
  • Frequency responce: 10-30,000 Hz
  • S/N >104 dBA at full power @ 0.1% THD
  • >80 dBA at 1W/1M
  • Remote gain control, mounting hardware & screws included
but I don't believe most of these. Many manufacturers embellish what their products can actually do! With the bigger more established brands such as JL Audio you will have no problems, their products have been tried & tested so much on the competition circuit.
Posted on Dec 28, 2007
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
tech48
  • 624 Answers
SOURCE: Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
Posted on Jun 16, 2008
uge44
  • 226 Answers
SOURCE: 500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Posted on Nov 19, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Jan 11, 2017 | Rockford Fosgate Car Audio & Video
Can I wire two p3 12 Rockford fosgate subs to a kicker 250.1 amp
It has two speaker terminals which allows you to wire muliple subs to the amp easier than trying to cram the wires all into one set of terminals. The two sets of terminals are wire in parallel internally on the amp, so it matters no which + or - you use on it. However, you need to remember they are already wired in parallel internally, so if you were to wire up two 2 ohm subs, the amp would see a 1 ohm load (which it's not stable at), not a 2 ohm.
May 04, 2015 | Rockford Fosgate Car Audio & Video
I have two 10 inch jl audio 4ohm subs.to run them both should i just run them parallel and if so does that change the ohm
I hope you find the link below useful to understand. Running them in parallel is the most common install. You cannot post pics in here and this really helps in understanding so check the link below out:
http://www.hifisoundconnection.com/Shop/Control/fp/SFV/30046/view_page/Subwoofer_Wiring_Ohms_Law
Jan 30, 2013 | Rockford Fosgate PUNCH P1000X5D
My subs cut out everytime I hit a bump.
I would say the wiring, in particular the earthing for it, also check any "Compression" fixtures.and check ALL joints etc. To be sure give the actual Amp a gentle tap, and see if that brings on the fault.
Feb 21, 2010 | Rockford Fosgate Punch 401S Car Audio...
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
