Question about Kenmore Kitchen Ranges
970 686321 I ordered a replacement dual (6" & 9") element and when it arrived it was the wrong part and the ceramic ring was cracked in three places. When I try to get a parts list the model number isn't recognized.
  • 146 Answers
SOURCE: Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Posted on Dec 21, 2007
  • 146 Answers
SOURCE: GE Stove
I'll need a model number to determine what's going on and whether the part is really a generic. They should have given you some kind of installation instructions.
Posted on Dec 24, 2007
philbran
  • 242 Answers
SOURCE: Glass cook top has cracked ...
They are expensive but not very hard to change if your carefull. They are about 300-400 on the norm , You may be able to get a new oven on sale for that much ,its up to you. Check with sears parts first. good luck
Posted on Dec 30, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
tony2155
  • 64 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
How do I replace a ceramic top to my rangemaster Toledo 90 cooker
This job is for qualified person. Is not recomadet to doit yourself.
Mar 30, 2014 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I have a G0504 16"
Contact Spaceage Ceramic Guideblocks at FAX 916 660 9975 for after market ceramic guides for this particular saw. They also do custom ceramic guides and thrust bearings.
Mar 20, 2011 | Grizzly H7873 Ceramic Guide Set G0513G0514...
I have a Patio 1. For the last couple of years,
It sounds like your ceramic elements are cracked and will have to be replaced. This can happen when cold juices drip directly onto the red hot ceramic elements. The cracks can sometimes be hard to see. The latest generation of TEC grills have done away with these ceramic elements.
Feb 23, 2010 | Tec Patio II Grill
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
How do you replace an ao smith ust 1152 pump?
1. Shut the power off.
2. Disassemble the pump case by unscrewing the
bolts holding it.
3. Take the impeller (rotating element) off the shaft,
as well as the impeller cover (difuser) if there's
any.
4. Take off the mechanical seal taking care of the
ceramic seat, and the carbon ring. Should this
break, you have to replace it. Just leave the
ceramic seat in place.
5. Now, you can take the motor off from the pump
housing.
6. Now, you can mount the replacement A.O. Smith
electric motor to pump housing.
7. Remount the mechanical seal, the same position
when you take it off.
8. Then, remount the impeller, the difuser, and the
pump case cover. Take care of the O-ring serving
as gasket.
9. Once you reassembled the unit, reinstall it, prime
it up.
10. Put the power on, and start the pump. Okey.
Sep 12, 2009 | Plumbing
Front side heat element with ring wont light on ( or heat up)
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
Aug 18, 2008 | LG LRE30451ST Electric Kitchen Range
Dec 21, 2007 | Maytag MER5765RAS Stainless Steel Electric...
How to fix a crack in ceramic top
Mine cracked and I ordered a replacement shipped overnight. I can't get a repair person out before Christmas. Is it easy to do it myself?
Nov 18, 2007 | Whirlpool GJC3034 Electric Cooktop
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
