Question about Brother CS-8072 Computerized Sewing Machine
Bobbit thread on my Singer Stylist 457 will not catch
Im threading the Singer Stylist 457 machine that I just purchased. The bobbin thread will not catch when turning the hand wheel. I have no idea what to do now....i've no idea where to oil the machine but i've used some compressed air to clear out any lint but i'm not sure what to do next. Please help!
  • 208 Answers
Pull the slide plate open and watch the hook (the rotating part under the bobbin case). It should move around with no hitch.
If it does not turn, it has a broken gear. The model 457 has a vertical shaft gear that breaks and it's easy to replace.
Posted on Jun 19, 2009
    Problem Solver:
  • 11 Answers
From manual:
Bobbit thread on my Singer Stylist 457 will not ca - 3_24_2012_4_26_23_pm.jpg3_24_2012_4_26_43_pm.jpg
Posted on Mar 24, 2012
My Singer Stylist Model 416, bobbin doesn't work at all. It will not catch when I try to thread it, it doesn't move. What can I do?
If you are certain it's threaded properly, then the bobbin case is probably either worn or damaged and it might need to be replaced. Take the bobbin case out of the machine and check for signs of wear, scratching or dull spots that may indicate damage. Be sure it is properly seated in the machine too, as being even slightly off kilter will stop it working. I have also read that sometimes a bobbin case may settle a bit in its seat and that makes the hook too low for the thread to catch on it and I honestly don't know if there is a fix for that. You'd need a good repair guy, ideally one certified by Singer.
Oct 09, 2014 | Sewing Machines
How do I replace the motor on a singer stylist 457?
What a great machine! All metal parts. If you're sure it's the motor, you will probably have to buy another for parts. There are several for sale on ebay right now. If you are not a professional repair person, you may want to consult one before spending the money.
Aug 02, 2012 | Singer Sewing Machines
I purchased an older Singer Stylist zigzag model 457 sewing machine at a garage sale. It doesn't have the owners manual and the bottom thread gets all knotted up. It also is hard to feed the material...
I can definitely help you with the owners manual. Go to http://parts.singerco.com/IPinstManuals/457A_105_125_135_143A.pdf and you can download it direct from singer, no viruses, nothing. Just save it in Adobe format.
The bobbin thread problem is called a birds' nest and can be from a number of problems. First thing to do is to change your needle, especially if it was the one you bought the machine with. It may look perfectly straight to the naked eye. But it only needs to be a little bent to cause a problem. If this doesn't clear the problem up, make sure you're using a new bobbin, freshly wound. If the bobbin isn't wound properly or is an old bobbin that's slightly bent or not quite round, it'll cause problems, too. Finally, the machine may need a new bobbin casing. Do a google search for Singer sewing machine parts and search for a bobbin casing for a model 457. You'll remove the plate from the top of the machine CAREFULLY (the screws are small, so be careful not to lose them!). Take pictures if you need to with your cell phone so you can see what to do when you need to put the new casing in. Bobbin casings are usually $25-30. This is the last thing, and I would only do this if you see that thread is catching on something in the bobbin area when you're moving the wheel by hand.
I've tried to be clear on the last bit, but I realize it can be a little awkward. If you need any other help with that, please leave me a comment back. It goes straight to my email, so I'll see it quick and will get back to you right away. The manual doesn't help a lot with your bobbin problem, so I'll do whatever I can to help you through it and get you sewing. Good for you for finding a great garage sale find!
Jun 08, 2011 | Singer Sewing Machines
I rethreaded a bobbin and now cannot get the needle to pick up the bobbin thread. What is the trick? Singer Stylist zig-zag 457
make sure that your needle is a good, sometimes there is a slight bend or burr and you do not notice. Replace it and make sure that the flat side of the needle faces the rear of the machine, then hold you top thread end and lower your needle and watch it hook the bobbin thread (when you put your bobbin make sure you have it in your tension slot and there is at least 6 inches) then gently pull your top thread and pull your threads to the back (have at least 6inches or else the needle can unthread.
Aug 30, 2010 | Sewing Machines
Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Bobbin thread won't catch after changing needle in stylist 457. also what tool to use to change needle in serger
machine needs to be timed,,usually a 30-50 repair, could try dropping a needle just a tad bit to see if it catches
May 31, 2009 | Brother CS-8072 Computerized Sewing...
Brother CS-8072 Computerized Sewing Machine Logo
1,850 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
