Question about Conair Extreme Hand Held Fabric Steamer with Dual Heat
Orange light and no steam on the extreme steam dual heat steamer
Orange light along with green light but no steam
How do I fix ultra steam mop model s-c393 that will not produce steam
The steam generating element may have failed, in which case it would have to be replaced.
Oct 03, 2016 | Ultra Products GarryTM Ultra Light Vacuum...
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
The steam in my handheld steam shot does not seem to be very hot therefore the surfaces, specially cloth ones do not get clean properly. What should I do?
If it steams it is as hot as it is going to get. Water steams at 212 degrees F at sea level so the only way to increase that heat is to pressurize that steam to a higher density than sea level which is about 32lbs per sq. in. Your steamer has no method to pressurize that steam to increase that heat. Conversely, as the pressure decreases, say you live in Denver which is about 5000 ft above sea level, then that steam will only get to about 203 degrees F. (See: http://whatscookingamerica.net/boilpoint.htm) Steam Cleaning at best is a poor method of cleaning as all it does is saturate the clothing item with water, which in theory loosens dirt, but no way is provided to remove the dirt. A rug shampooer has a vacuum that sucks the dirt away from the carpet along with the suds for a better cleaning method. In my opinion a hand steamer will only remove wrinkles at best.
Mar 20, 2011 | Bissell Vacuums
I have a shark steamer, light is on but no steam. ...
Nope...no cleaning to it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Conair Extreme Hand Held Fabric Steamer with Dual Heat Logo
107 people viewed this question
Top Conair Vacuums Experts
JoeVacs
Are you a Conair Vacuum Expert? Answer questions, earn points and help others
