Question about Avanti Water Filters & Coolers
Water leaking all over the floor
When I put water jug on it is leaking on the floor.
2 Suggested Answers
  • 816 Answers
SOURCE: When i put water in my water jug it leaks out from
The only other option is , check to see if water pump is bad. you will see a leak from bottom of water pump if it is bad. If water pump is good. Replace the thermostat. Good-Day! And make sure recovery tank is not leaking! or the coolant system is not plugged somewhere.
Posted on Oct 29, 2014
Maytag MSD2650HES leaks out the bottom when we use the door water dispenser. It's 10 years old. Is it worth fixing or should we just replace it?
this fix could be a simple leaking connection or hose
you have some options
call a technician and have the problem properly diagnosed and get a quote
if the quote is around 40% of the price of a new unit then consider a new unit as parts for your unit will be at the no longer available stage lf you really do not water dispensed from the door , disconnect the system and use a jug of water in the fridge or purchase a water/ drink cooler but that is an option to consider
Aug 08, 2016 | Maytag MSD2650HES Stainless Steel Side by...
When i put water in my water jug it leaks out from sumwea n the truck is running hot What could that be
Oct 29, 2014 | Cars & Trucks
Why Kenmore refrigerator 7215 is leaking?
the condensing drawer is over flowing likely to much ice building up inside an defrosting . put some gallon jugs of water til the balance is ok between power and amount of ice present i use some 3 or 5 jugs of water.
orrrrr
you water hose is leaking . git a light an looksee
Aug 03, 2014 | Kenmore Refrigerators
My 1996 toyota camry ran heat. so i put water in the resevior tank. now i have to put water in every 3 days.
You need to find your leak. You should have a leak somewhere. You might have a loose clamp. Start your car and let it run for a few minutes. Watch for a leak. Water burns a lot faster then actual coolant. If your adding water, it evaporates. You need a jug of coolant. If you need anything else, let me know. I am here to help.
Feb 23, 2011 | 1996 Toyota Camry
My wf541 leaks from the soap dispenser drawer when water is being put into the machine
Reduce the water pressure, I assume its too high , also make sure no partial blockage at dispenser hose ..try pouring in a jug of water and see if it goes away Freely...Good luck
Feb 04, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a 1999 chevy malibu that has a coolant leak. The leak seem to be coming from underneath the fan belt end of the motor. As soon as I put water in the coolant jug it leaks on the ground.
Check the lower radiator hoses for a leak and the lower part of the radiator itself for a leak. Also, check your engine oil level and make sure you don't have water in your engine oil. If you do, you have most likely lost one of the timing chain guides and the chain has worn a hole in the front cover of the engine or the block has cracked. Another possible problem location could be the water pump leaking at the forward seal.
Jun 18, 2010 | 1999 Chevrolet Malibu
Radiator want stay full of water or antifreeze has plastic jug on fender weld
Is there a leak somewhere? There should be green or pink fluid on the ground if there is. The plastic jug is often called the overflow this has level marks on the side of it for when the vehicle is hot and cold, cold is at the bottom end of the jug. The purpose of these marks is so you can see the levels without having to open the radiator. When the engine is cold open the radiator, start the motor and look into the radiator there should be coolant at the top of the opening. If not add coolant while engine is running, note if it's pink it's the DEX/Cool, if green any over the counter coolant will do. Add until the level hits the top of the opening. Let the engine heat up and check the level again. If it's full put cap back on and note the level in the overflow jug. If engine is hot level should be at the top mark, be sure to NOT fill the jug to the very top as it needs the space to expand for any over flow from the radiator.
The system will pull extra coolant from the jug when it's cold and use it until the proper temperature is reached then it will "spit" the extra back into the jug. (that's why there are two lines 'hot' and 'cold') Never add water to the jug as it will cause the jug to crack if the outside temperature goes below freezing always add coolant/antifreeze.
Oct 10, 2009 | 2002 Chevrolet Cavalier Coupe
I have a leak my jug will not hold water or antifreeze i just had the radiator replaced is it my water pump
NO SOUND LIKE COOLANT OVER FLOW JUG HAS A HOLE IN IT REPLACE IT SHOULD FIX THE PROBLEM.
Sep 30, 2009 | 2000 Oldsmobile Alero
Water Filters & Coolers Logo
29 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
