Question about Acer Aspire 4720 Notebook
I turned on the unit and it takes me to the options to either start up recovery or start up normally and nothing happens.The ac adapter is fine and the battery is still new.
  • Art Ellison
    Art Ellison May 11, 2010
    OK--what happened last time you used it? Did it work? Did it shut down properly? Can you start in safe mode?
    Sergeant:
    Champion:
  • 253 Answers
This is sometimes happen not serious one and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
Toshiba Satellite L355-S7812 keeps restarting with AC Adapter plugged in
Your OS has a corrupt element in it that makes unit shut down every once in a while. Try repairing the OS. Or try a system restore. If nothing works and it still bugs you reload the unit.
Sep 06, 2017 | Computers & Internet
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
When i turn on my acer aspire one d2501821 notebook it freezes on the windows screen
Try doing a system restore and it that doesn't work, try doing a system recovery.
For doing system restore, power on the netbook and keep tapping F8.
This will take u in to the Windows advanced options.
Try safemode.
While getting in to safemode, it will ask u whether u want to use system restore.
Start system restore and select a date in which the computer was working fine.
To do recovery, power on the netbook and keep tapping Alt+F10.
That will take u in to the recovery mode.
Select complete system recovery.
This process will take around 30 to 45 min and make sure u plug in the AC adapter.
Dec 02, 2010 | Computers & Internet
My acer on one netbook wont boot up, the power light comes on but nothing else,
Try removing any external device first (ex. USB device) then draining the flea power:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Hope this helps
Dec 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
REPAIRING WIN XP FOR A HP 530
If repairing the XP installation is not solving your problem, you can try a clean install by formating your drive and re-installing XP.
Jun 29, 2009 | HP KP497U9 Notebook
Panasonic DMC-TZ5 will not turn on
I had a similar experience, both with my original TZ5 and the replacement TZ5 Panasonic sent me. I was mystified at first, but now I think it's the AC adapter I was using. With the replacement camera, absolutely nothing happened between taking pictures of my new house and plugging in the camera to export the photos. The back of the camera near the AC input got really hot and my surge protector shut off. The camera won't turn on. I don't know about warranties, but if you think that's the problem and were using a Panasonic AC adapter, you should check. My (non-Panasonic) adapter worked ok the first time or two I used it.
Jun 15, 2009 | Panasonic DMC-TZ5 Digital Camera
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Laptop not working
Disconnect the battery and the AC adapter from the computer.. Hold down the power button for 2 mins. Now connect the AC adapter only..
If it was an issue with the static electricity then it should fix it.
Else try changing the wall outlet and chk if the connections are fine.
If the brick on\f the ac adapter does not get warm then probable the adapter has gone bad and need to be replaced.
If the it still does not work then you can also try reseating the ram and the hard drive.
If all the above does not work then probable the power module on the nb has gone bad and need to be repaired.
Regards,
Anup
Apr 05, 2009 | HP Compaq Evo n610c Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Acer Aspire 4720 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
