Question about Intel Motherboard
My system reboots several times before logon screen appears.. whenever i restart my pc it happens or when i shut down the pc it happens//
  • 1,601 Answers
Re: My system reboots several times before logon screen appears.. whenever i restart my pc it happens or when i shut down...
What operating system are you using?
Posted on Nov 03, 2007
0 characters
3 Points
Fatal Error, Chasis Entruded, System halted appear at first time boot up. and if I again restart, sometime it works continuously till I shut down the PC and if I boot up again some times it works or some...
Good day try to remove the memory card, sound card and video card, clean the copper leads using an eraser and try to check all the connectors specially the hard disc, do this and it will resolve the problem, best regards.
Aug 19, 2011 | ASUS P5PE-VM Motherboard
Sir, whenever i start my computer, i face a
change the cell inside present on the motherboard
Dec 17, 2010 | Intel Motherboard
System boots several times.
it's PC? you try change for the power supply
Dec 15, 2009 | Intel Motherboard
My Msi 865gm2 motherboard won't complete loading windows (any)
1.switch on your computer and press F8 to enter in safe mode of your XP
2. rightclick mycomputer,then properties,then hardware,then device manager, double click on the
display adapter
3. right click on the display adapter and uninstall it or disable it.
4. double click on sound & volume and controller, right click on the sound devices and uninstall it or
diable it.
5. restart your computer..
6. now your system will enter into Windows XP and it will detect your hardwares, if it ask for the drivers
just cancell it till your desktop screen appears...
7. uninstall the driver softwares which you have installed before for the display and sound devices...
download your required configuration drivers from the given link.
Jun 20, 2009 | MSI 865GM2 LS P4/FSB...
Blue screen appers and shut down by itself
your boot files are corrupted please repair your operating system backup your data and plan to reinstall a fresh version of operating system. endeavor to scan your system for virus affections.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Blue screen
Simply change your Ram with new one.
Apr 08, 2009 | Motherboards
Problem of blue screen error messege
you have installed the inf setup or not, install all the updated drivers of your motherboad
Oct 03, 2008 | Intel D102GGC2 Motherboard
PC spontaneously rebbots
Hi rogermx,
You’re temperature is great. No trouble there. You can try this with Windows XP. Open system properties. Click on the Advanced tab. Go down to, Startup & recovery. Click the settings button. Remove the green check mark next to: Automatically restart. Click Ok. Than restart your system. The next time you're system does a restart all by its self you should receive an error message on screen. Hopefully you have time to write it down.
Post the error message here if you can't find a fix for the error.
Windows may need the system to restart a few times before you receive an error message. Try this before I add more suggestions.
Aug 05, 2008 | Biostar P4M890-M7 Motherboard
Still a problem
the blue screen flash and restard is actually a critical system message, but windows is set to restsrt the system on a system failure, if you want to read the message, start the computer and tap the "F8" key until a menu appears, one of the options will be "disable automatic restart on system failure" select this option and the next time it happens it will stay there.. but from what you are describing it is pretty evident you have bad ram, the long beeps you are hearing is the mainboard signalling a critical error, usually caused by ram, get new ram and i think you will have no problems
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
May 06, 2007 | Abit KN8 SLi Motherboard
Intel Motherboard Logo
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
