Question about Bass Pro Shops Aluminum Fish Fryer
I can not adjust the air flow on my fish fryer to get the correct flame. there is not enough adjustment in the vent to provide adequate air flow
My lpg fryer IFS40 burns yellow flame and on the recent inspection tech supposedly found corroded heat exchanger. The fryer is only half a year old and still under warranty but the imperial only offer
The heat exchanger might be a result of the yellow flame but not the cause of it burning yellow. I would guess it is the amount of air being mixed with the gas. Most burners have a slotted metal air mixture ring on the front of the burner near the brass orfice, you are calling a jet. There is a locking screw to release the ring so it can turn to adjust the amount of air being mixed with the gas. If this doesn't fix the yellow flame it could be a gas pressure problem that could be the external regular in the gas line. Not sure if you are talking about the pilot flame or the burner flame or both? A tech should know how to adjust the air mixture.
Oct 15, 2014 | Imperial IFS40 Deep Fryer
Can anyone tell me why my direct vent fireplace flame looks like its in a wind storm. The pilot blows out as a rexult
Looks like too much yellow in the flame. That is normally caused by the mixing control on the gas feed tube being too closed. Trace the tube from the burner .....back toward the gas feed line....until you find the slip ring that controls the amount of oxygen that is mixed with the gas. Open is a small amount and light it. You should see a bit more blue color. If that does not work, continue to vary the adjustment until the flame burns correctly. The pilot should never blow out unless the outside air feed is too large. You can try blocking it a small amount to see if the smaller amount of outside air corrects the problem.
May 16, 2014 | Home
What does the gas adjustment screw look like on a lg400 gas fryer
There is no gas adjustment screw. There is an air ratio adjustment on each burner. Loosen the screw that holds the flame adjuster and turn the stamped metal adjuster until there is no orange portion of the flame visible. Tighten the screw and you're done.
Oct 12, 2013 | Imperial IFS40 Deep Fryer
How to adjust the air for blue flame
there are factors to be considered in acquiring correct or blue flame in fryers, 1st- the correct ratio of gas to air mixture, 2nd- cleanliness of and correct gas supply pressure and burner condition.
Mar 29, 2011 | Vulcan Kitchen Appliances - Others
How can I convert from natural gas to LP?
change your gas get from natural to lp and use an lp regulator. you may have to adjust your air flow for proper flame
Sep 16, 2010 | American Range AF-25 Deep Fryer
What color should the burner flame be
The burner flame should be blue.
If you have the spider air flow open to wide the flames will be yellow.
This means the gas flow has to much oxygen.
Typically the air vent should nearly closed.
You may not be able to remove all the yellow and have a few Yellow tips.
This is ok, just try to adjust were you have the last amount of yellow in the flames.
Hope this helps.
Jul 18, 2010 | Weber Genesis Silver B Grill
I got problem with my cecilware gas deep fryer fms 40, i was able to turn on the pilot, then i turn it to full on possition, but the fire will go out when i was trying to adjust the thermostat, please...
Make sure the flame is staying on the burner and not lifting away from any sensors in the flame. You may need to adjust the air bands on the burners to get the flame to stay down. Also make sure the vent in the back is free of blockage.
Feb 13, 2010 | Cecilware FMS-40 Deep Fryer
I have two dean sr142gps fryers and am looking for an owners manual. I want to know how to adjust the flame onthe burners.
The only way to adjust the flame is by changing the orfices on the burner tube manifold. Dean is owned by Frymaster & you can contact their technical Dept @800-551-8633
Jul 19, 2009 | Kitchen Appliances - Others
Pilot Light does not stay on
Did you change the thermopile?Its a cheap part.Let me know.
May 14, 2009 | Pitco Frialator 35CS Deep Fryer
Flame does not seem hot enough - too much yellow flame.
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Jan 05, 2009 | Kenmore 63942 Dryer
Bass Pro Shops Aluminum Fish Fryer Logo
44 people viewed this question
Top Bass Pro Shops Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bass Pro Shops Kitchen Appliances - Other Expert? Answer questions, earn points and help others
