Question about Canon imageRUNNER 3035 Black and White Copier
How to remove the xerox readings - Canon imageRUNNER 3035 Black and White Copier
Xerox 7328 touch screen not taken
I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working.
Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support
Thanks,
Sep 05, 2014 | Xerox WorkCentre 7328 Multifunction laser...
Xerox Workcentre7242 fault/error 116-324. About 2 seconds after the menu appears the fault/error displays.
That indicated the machine is not reading the DIMM network chip.
I would think removing the memory chip , cleaning it and reinstalling it would resolve the issue. It is possible the network board is bad. I suspect just an iffy connection with the DIMM memory .
Jul 08, 2010 | Xerox Phaser 6130 Laser Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
My xerox 8500 will not read that I have paper in the tray and the screen is blank, I can't read anything.
Call Xerox at 1-800-835-6100 report that problem and they will send you a display. It is a known problem and they will correct it .
Nov 04, 2009 | Xerox Phaser 8500/DN Printer
Changing the language display on xerox n40 printer
IF YOU CANNOT READ RUSSIAN, THEN MAY I SUGGEST ADD AND REMOVE, DELETE SOFTWARE FOR THIS PRINTER AND THEN REINSTALLING THE SOFTWARE, IT SHOULD THEN ASK YOU WHAT LANGUAGE YOU REQUIRE.
Jun 16, 2009 | Xerox DocuPrint N40 Laser Printer
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
PHASER 8550DP
Your yellow ink sensor is stuck
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Mar 08, 2008 | Xerox Phaser 8550DP Printer
PHASER 8500 XEROX
Is the display saying NOT READY, or is it not comming on.
If the display is blank there is a known problem with those displays and Xerox will replace them free of charge.
If you have a blank display, call 1-800-835-6100.
If I am misunderstanding the issue provide more details please.
Feb 29, 2008 | Xerox Phaser 8500N Printer
Canon imageRUNNER 3035 Black and White Copier Logo
12 people viewed this question
old marine
old marine
