Question about LG 37LH30 37 in. LCD HDTV
FAB30016430 LG Television Screw - LG 37LH30 37 in. LCD HDTV
Tv clicks butb wont turn on
If Your television clicks and the bulb wont turn on, then it means the lamp of the television is bad and need to be replaced. The clicking sound is caused by the power reaching the unit but being unable to be used up by the television. You need to replace the lamp to be able to use Your television. To replace the lamp, You will be needing these instruments, a cup, screw driver, replacement bulb and a hand glove. Then You follow the steps below:
  1. Power off the television,
  2. Unplug it from the power outlet and allow the television rest for about 6 hours so the high voltage on it will dissipate as television is well known to store high current after being plugged from a power outlet,
  3. Then You Wear Your hand glove to avoid some sort of shock,
  4. Then You unscrew the lamps compartment and put the screws into the cup in order for You not to misplace them,
  5. Then you turn off the lamps switch that is by the side of the lamp,
  6. Unscrew the screw that is holding the lamp to place,
  7. Carefully pull out the lamp from its casing and replace it with a new one,
  8. Reverse the whole process to reassemble the television back together and remember to turn on the lamps switch,
  9. Plug Your television and power it on.
Hope this was helpful. Thank You for using FixYa!!!
Jan 16, 2011 | LG 42LC2D 42 in. LCD HDTV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Help. I can't get the stand off my LG 42LG50
On the back of the TV, there are 4 screws holding the stand. Remove the 4 screw and the stand will slide out from the bottom.
Jun 10, 2009 | LG 42LG50 42 in. LCD HDTV
Bulb is out
First unplug the AC feeding the set look in your owners manual for location of lamp door cover you may need a flat head screw driver. After locating the door and lamp it is just remove old lamp and firmly install new one do not get finger smudges on new lamp or try LG for help on line an online search for their customer website there you should find instructions to replace lamp
Aug 30, 2008 | LG RU-52SZ51D 52" Rear Projection...
Changing lamp on lg dlp
On my unit there's a panel on the lower right hand side, remove the 2 screws with a screw driver. Inside you should see a compartment that is metal and has a thin metal handle. Remove the Black screw on the top left hand side. Then pull the unit out with the handle. Inside the unit holds the bulb, just replace and go through these steps in reverse to place back together.
Aug 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
LG RU-42PZ90 42
I don't have a solution but I do have the same unit with vertical lines on the screen. I just had a tv guy come and diagnose my issue and he recommended I part it out on ebay. I'm interested first in trying to fix myself. Are you interested in selling me some of your parts?
Jul 13, 2008 | LG RU-42PZ90 42 in. Plasma Television
Red Light just came on
Lamp burned out...take front cover off of TV should just pop off...behind that is two removeable panels...on my PT-50LC13 the one on the left has one screw to remove the panel and one screw holding the lamp housing ....loosen the screw and pull the housing straight out...now here is the tough part...reach in your wallet and pull out about $255 to get a new one...I ordered off of the internet...local shops want around $300
Oct 29, 2007 | LG RU-44SZ51D 44" Rear Projection...
Open Questions:
See all LG 37LH30 37 in. LCD HDTV Questions
LG 37LH30 37 in. LCD HDTV Logo
42 people viewed this question
Computer Repairing
Computer Repairing
