Question about Rheem Water Heaters
Power vent pvs40-36fy
No hot water
Water heater anode
If you have power vent, the anode might be located in a separate port on the top under the power vent.
Otherwise, the anode can be a 'combo' and connected to hot water nipple.
Copy following link for more information
http://waterheatertimer.org/Replace-anode-rod.html
Aug 07, 2012 | RTO W4 A.O Smith Gas Hot Water Heater...
Hi i have a power vent water heater model #-6g40pvw-40f. It go's into lock down mowed one light lit on vaction two more on A-and B is it the heating element or lighter mechanison thank you mike from...
Hello Mike,
Check gas pressure, burner parts need to be cleaned, check electrical outlet, hot surface igniter is bad
White Rodgers intellivent error code:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
Error code says: system in lockout, but you know that.
1) Low gas pressure, no gas to water heater: call gas company to check pressure
2) Hot surface igniter not positioned correctly: inspect and clean burner parts.
http://waterheatertimer.org/images/Reliance-hot-surface-ignite.jpg
3) Low voltage to water heater/ outlet has wrong polarity: Use circuit analyzer on electrical outlet to make sure polarity is correct
Typical power vent manual:
http://waterheatertimer.org/pdf/Reliance-40-50-power-vent.pdf
Cleaning water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
http://waterheatertimer.org/pdf/How-to-clean-combustion-chamber.pdf
Jun 19, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Mar 16, 2009 | Water Heaters
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
16 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
