Question about Irons
Disable auto shut off - Irons
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
How to disable the auto shut off switch?
You can't. it needs to be repaired.
Jun 05, 2014 | Rowenta DZ1700 Iron
Need to disable or fix auto shut off
www.laundry.manualsonline.com has free manual
Apr 11, 2014 | Sunbeam Irons
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
My iron will not stay on.
that is probably the auto shut-off in the iron causing it to turn off, check the manual for how to disable it
Nov 21, 2009 | Rowenta Professional DX8900 Iron
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
Iron Shuts off Automatically when using iron.
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 03, 2008 | Conair DPP4000 Iron
Auto shut off on/ wiill not heat
Hi! Ensure that the unit is tightly plugged into a working outlet.
Some units are equipped with our patented Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat.
Jan 12, 2008 | Rowenta Power Duo Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
