Question about Craftsman 24 Hp 48" Deck Yard Tractor
I just recently sharpened my blades and when I put them back on and tried to mow, the mower didn't move. I looked under and discovered that the transmission belt had slipped off of the back pulley next to the wheel. I though I put it all back on right, but when I tried to start it, the mower would jump like it was in gear even with the clutch pushed in. Any ideas? Can I get a diagram from somewhere?
  • 341 Answers
I have ordered manuals from sears before for older craftsman model equipment so check out there website and see what you can find.
Posted on Jun 19, 2009
5-h-push mower has bad veberation blade is on tight
bent blade, bent crankshaft, blade not balanced are all possible causes for vibration.
If you sharpened the blade recently try rebalancing it.
You could have struck something while mowing and bent the blade or bent the crankshaft on the engine.
If blade is bent replace it. If out of balance, rebalance it.
If crankshaft is bent replace it, have it straightened or replace the engine.
To replace or straighten the crankshaft it will require engine tear down which requires knowledge and tools for small engines.
Apr 22, 2016 | Garden
I have a florabest electric lawnmower, the blades are turning and were sharpened recently but it is not cutting the grass...any ideas?
check that the blades were put on correctly and the sharp side is in the right position . if not then the blades are trying to cut the grass on the back side un sharpened side.
Jun 02, 2013 | Garden
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Bolt comes loose and rip cord is yanked from hand
  1. block off the blade and driver assembly with a 2x4 to keep it from moving
  2. remove the flywheel nut (regular hand force should be sufficient)
  3. tap the 3 holes on the flywheel (if they aren't already threaded) using 1/4inch 20national tap set
  4. remove the flywheel using a flywheel puller -- a harmonic balancer puller which matches the tecumseh bolt pattern on the flywheel also works using 3 1/4inch thread (20national, 2inch long) bolts with washers
  5. NOTE: (if the blade was removed/reinstalled, tighten the blade to manufacturer's spec of 60lbs) before installing the new flywheel key
  6. remove the sheared flywheel key
  7. clean up the flywheel (wipe off all the dirt and grease)
  8. install the new flywheel key (part 611004 for toro 20016)
  9. install the flywheel (pull the bail brake handle to get the ball-brake inside the flywheel)
  10. tighten the flywheel nut to manufacturer's spec of 37.5lbs
  11. prime the gas bulb, give it a pull and mow away
Aug 24, 2009 | Toro Lawn Mower With Toro Power Tools
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt slipped on the poulan self propelled lawn mower
The belt hopped off likely due to grass or other things getting in-between the belt and pulley near the blade. You should be able to remove the cover on the top of the mower deck, remove the belt from the pulley under the cover, place the belt back on the pulley near the blade and then on the pulley under the cover. If the belt is shiny on the sides or you see black powder caking the inside of the cover or area's around the pulleys or the belt looks like it has chunks missing from any part of it the belt should be replaced. local hardwares, automotive and DIY centers that carry outdoor power equipment parts can match it up with the one the manual recommends using.
Tip: Keep the blade sharp, I recommend buying a couple blades so that you can always have a sharp spare installed while the other is being sharpened, change the blade as soon as the sharp edge is gone and becomes somewhat rounded on the cutting edge. If the lawn produces a lot of dust or there are lots of bald patches this will dull the blade quickly as will chopping up stick with the mower, if this is the case take steps to improve the lawn and keep the sticks picked up before you mow.
Change the oil before using it in the spring and after each 50 hours of use (more often if its used in a dusty area).
I recommend using a synthetic oil unless the manual specifically states not to.
When mulching mow in counter clockwise circles, when bagging mow in clockwise circles and in either case overlap about 1/4 the width of the mower for a complete smooth cut. after each mowing allow the mower to cool then tilt the mower on its side opposite of the carburetor (where the air filter is) and wash off the stuff stuck to the bottom, you may have to use a putty knife on the real thick or stubborn stuff. This will reduce corrosion over the years and keep the mower running and mowing efficiently not mention it avoids blowing into the air backteria produced as the clippings of past mowing decay (it makes me sneeze).
May 14, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 24 Hp 48" Deck Yard Tractor Logo
225 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
