Washing machine fault
My hotpoint wf740g has f-02 flashing it happend as it was going into spin cycle we have just replaced the motor
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Washing machine wont spin f-02
The Hotpoint F-02 error code is associated with a Motor Fault, now strange as this may sound, but it possibly wont mean the motor is faulty, it simply means the main PCB in the machine has sent a signal for the motor to start, but it's not receiving one back to say it is going.. Usually if you can turn the drum by hand, then the fault would generally be the Tacho of the motor, this is a small device on the back of the motor with two wires coming from it. Check to make sure the Tacho hasn't come loose or fallen off, then one by one remome and reattach the connectors going to the main PCB, vibration can cause these to become loose...Good Luck
Jun 26, 2014 | Hotpoint Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt761 is flashing f-02
f-02 Motor jammed tacho detached this is as it states a motor issue with your unit you would have to remove the motor to test if the motor is at fault if it is you would replace the motor Thanks Rick
Mar 22, 2011 | Washing Machines
My hotpoint wt741 washing machine hsa stopped doing full cycles and flashes an error message F-02
'F02' for Hotpoint/Ariston and Indesit (who makes them) decodes as 'motor jammed/tacho detached: check motor and module connections'
The good news (probably) is that often these faults are cured by disconnecting the module (PCB) cables/plugs and reconnecting again, a fairly swift operation. I suppose the bad news is that you will need a service engineer to carry it out?
Hope this helps. and good luck!
John C
Mar 16, 2011 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
