Question about Masterbuilt Kitchen Appliances - Others
Turkey fryer not hot enough after turkey dropped in oil
  • 4090 Answers
SOURCE: can not get my oil to heat more than 250 degrees
make sure the knob is actually anchored to the shaft. There is a screw that binds the knob to the flat spot on the temp control. This should be tight so the shaft turns not just the knob. If it is firm then your temp control is faulty and needs to be replaced.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
SOURCE: missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Posted on Nov 26, 2009
SOURCE: brinnkmann turkey fryer 815-4001S Will not
use a center block to keep the red switch up and your good..that's what we did
Posted on Nov 25, 2010
woobie dog
  • 1273 Answers
SOURCE: my brinkmann turkey fryer doesnt get up to boiling temp
Hi Larry, W/D here. Just got your question so I'm a bit late in getting back to you......
The amount of heat delivered at the burner is dependent on a number of things, and we'll take them in the order of most likely:
1st, The gas tip must be clear. It's possible for critters to build nests in the gas delivery piping that can plug either the gas delivery port or the air side of the mixing venturi; both will give you a reduction in BTU's. Compressed air can be used to blow out the air side of the venturi. The orifice for tha gas can be cleaned with a thin wire, or use a tip cleaner, available at a welding supply store. These are inexpensive.
2nd, The burner proper can become plugged at the ports where the mixed gas/air combusts. These can be cleaned with a small drill bit,sized to the holes, and just passed back and forth to clean them out. Compressed air works well to remove any particles remaining.
3rd, The regulator may be defective. If this is the case, you'll need to replace it as it contains no user serviceable parts.
4th, the in-line regulating valve may be sticking in the partially open position. This is difficult to diagnose, however, and is more of an assumption, after all other causes are eliminated. The cure for this is replacement also.
Hope that this was helpful to you.
Best regards, --W/D--
Posted on Nov 04, 2011
  • 3 Answers
SOURCE: How hot does the oil has to be to fry 19 lb turkey
Oil needs to be 350 degrees for 55 to 60 min hint put a slice of raw onion to keep oil from burning up
Posted on Feb 11, 2012
I would like to download a manual for the big boss oil-less fryer
PDF]big boss oil-less fryer instructions 12-12-11 - The Home Depot
www.homedepot.com/catalog/.../a5/a5961b72-678c-4b49-b11f-c7af721ad7ad.pdfDec 12, 2011 - Just fill it with your choice of oil. Then spray it lightly over the food prior to cooking (1 to 3 sprays). 3. You can increase the capacity of your BIG BOSSOil-Less Fryer when cooking large foods such as a turkey (up to about 16 lb.).
Big Boss Oil-Less Fryer (1300-watt / 16-Quart) - Hot Air Frying
www.hotairfrying.com > Models of Hot Air Fryers > Countertop Convection OvensRecipe book: small recipe book (additional recipes on fan sites such as http://cookingupthecure.com/category/recipes/big-boss-oilless-fryer/ - link valid as of ... big boss oil less fryer Google Search
Mar 25, 2017 | The Kitchen Appliances - Others
Why wont the skin get crispy in the Butterball turkey fryer. We have tried everything.
element isn't getting hot enough. maybe only heating half way. need to replace element and or controller temp inside without food should reach 425 deg.
Nov 02, 2016 | Masterbuilt BUTTERBALL Indoor Electric...
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
Tried to fry a turkey yesterday but I could not get the oil hot enough. I was using vegetable oil.
oil does not matter,any cooking oil will work, olive oil is the least desireable , you must have a good strong gas flow to your burner to get the oil temp correct
Nov 29, 2013 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Need instruction manual for deep fryer model 9514
How long two cook a 20 pond a how hot do I make oil
Apr 14, 2012 | Brinkmann 815-3786-0 Turkey Fryer
I deep fried my turkey for 1hr but the legs were still not done and the skin was not crispy. The rest of the turkey was cooked and the bones were brittle enough to snap the legs off easily. What went...
make sure that u have the right amount of oil of ure choice and 5 min per lb probe with fork if it spins freely turkey is done ( FYI after you checked ure turkey take out of oil and dust turkey with some seasoned flour drop back in oil for 2 min for great outside crust as said in louisiana "that what u call a deep fryed JO---JO
Dec 29, 2010 | Brinkmann 815-3786-0 Turkey Fryer
I would like to make french fries in my outdoor turkey fryer. How hot should the oil be? and how many fries can we cook at one time and for how long?
Get yer oil to 375. You oughta be able to load in a bag of frys at a time slowly. Shouldn't take long. Who's army are ye feedin?
Dec 20, 2010 | Eastman Outdoors 37042 Turkey Fryer
Missing instruction manual for Charmglow Electric Turkey Fryer
Nov 26, 2009 | Kitchen Appliances - Others
The oil should be hot enough so that when a drop of water is droped into it the oil will sputter, but not not hot enough to cause any smoking vapors!
Nov 27, 2008 | Masterbuilt 20010306 Deep Fryer
Kitchen Appliances - Others Logo
46 people viewed this question
Top Masterbuilt Kitchen Appliances - Others Experts
Richard Lilja
Richard Lilja
Angel Joseph Jr.
Angel Joseph Jr.
Sock Puppet
Are you a Masterbuilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
