Averdigi eb3004 md
My security camera is frozen with red spot sign flashing on and off how do i resolve
How to empty a full hard disk for the eb3004 md
boot with a windows cd/dvd and delete all partitions and then create one and install windows.
Sep 08, 2014 | Computers & Internet
Remote contol does.'t work
There's not much to go on here, but lets start with the simple things first. Check the following:
1) Batteries (be sure that they are in correctly)
2) Use a camera and look at hte remote while puching a button, you should see something in the camera.
3) If you have experience with TVs, open up the unit and check the infra-red receiver. Quite often the solder connections for these go bad which will generate enough noise to cause it to fail.
Check these and update this with your progress.
Good luck,
Dan
Oct 08, 2012 | Avermedia AVerDiGi EB1304 Net
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
White ink printing with alps MD 5000
To print white, you need to use the spot color option in the printer properties. The object to be printed must be all black. It seems counter to what you might think, but the spot color mode will print the solid black areas as the selected spot color.
Mar 09, 2010 | Alps MD 5000 Thermal Printer
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Panasonic camera md 9000 it has reset problem
you have problem with socket cylinder head..you can't repair this problem, you must bring camera to panasonic service center
Jul 01, 2009 | Panasonic NV-MD9000EN Mini DV Digital...
Red flash and appears to be frozen
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
Jan 06, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Help with red flash?????
Do you mean, the AF Illuminator (the bright orange/red light that appears before the picture is taken)?? If so, all have to do is click on menu, scroll all the way to the right (into the setup menu) and go to the camera icon. From there, go down to the AF Illuminator and switch it from "Auto" to "Off".
Hope that resolves your problem!!
Nov 29, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
