Question about 2K Games Borderlands
Need serial code for borderlands
The game is for pc, the code is for the dlcs.
Why does my 2003 Aztec show error on the odometer and won't start?
The IPC calculates the mileage based on the vehicle speed signal circuit from the powertrain control module (PCM). The odometer will display ERROR if an internal IPC memory malfunction is detected or there is a class 2 communication fault. The odometer displays either miles or kilometers as requested by the activation of the English/metric button on the driver information center (DIC). The associated indicator (km or MI) illuminates.
You probably have A class 2 serial data communication malfunction. All the Modules on your vehicle talk, share information on the data network an if something brings it down ,shorts it out, the vehicle will not start .
The data link connector (DLC) allows a scan tool to communicate with the class 2 serial data line. The DLC is a standardized 16 way connector located below the instrument panel and close to the steering column. Both the connector design and location are dictated by industry wide agreements. All DLCs are required to provide a power supply, hot at all times, to terminal 16. This circuit is used to power the scan tool. All DLCs supply a power ground at terminal 4 and a signal ground at terminal 5. The class 2 serial data circuit is provided at terminal 2 of the DLC.
You probably need to take this to a ASE certified repair shop or the a GM dealership ! Because if you are asking here you probably don't know about this stuff, an you sure don't have a factory scan tool to see which modules have DTC'S - diagnostic trouble codes stored .
You
May 21, 2015 | 2003 Pontiac Aztek
Borderlands cheats codes
Hello! Sorry to tell you, but Borderlands unfortunately doesn't have any cheat codes available for the Xbox 360. However, you can mod your saved game using a program called Modio that changes certain features of your game such as the amount of money you have or how strong your guns are.
I recommend you do some research into altering/modding your game saves, as it may not be suitable for everyone. However, it does open up the possibility for cheats, so it's entirely up to you. Good luck! :)
Aug 19, 2014 | Microsoft Xbox 360 Console
How do i past level 50 on borderlands 2
You need to download the DLC or patch to go above level 50.
The maximum level in Borderlands is 69 with The Secret Armory of General Knoxx and patch 1.4.1 installed. Players with only the patch are limited to level 58. If neither the DLC nor the patch is installed, the maximum level is 50 in non-Game Of The Year editions. The maximum level in Borderlands 2 is 50, with an increase to 61 after the Ultimate Vault Hunter Mode patch is released on April 2, 2013, and a further upgrade to 72 after the release of the Ultimate Vault Hunter Upgrade Pack Two: Digistruct Peak Challenge.
Jul 16, 2014 | Sony Playstation 3 (PS3) Console
http://www.ign.com/cheats/games/borderlands-ps3-957207
How do i past level 50 borderlands 2
Xbox 360 hardware problems
Go to the setting then go on storage then you should see the option to press Y press that it will clear all updates on your console now try borderland and re download the up date and see if it persisted
Oct 18, 2012 | Microsoft Xbox 360 Console
Xbox wont read brand new games
Check with xbox to see if there is a firmware upgrade for the player to cope with the later disks coming out.
Sep 07, 2017 | Microsoft Xbox 360 Console
Borderlands 2
I make Logitech gamepad profiles. I just made one for Borderlands 2. Just download it and follow the instructions. It will save you all the hassle. Go here and look for the Borderlands 2 profile:
http://bit.ly/Logitech-Gamepad-Profiles
Sep 21, 2012 | Logitech Rumblepad 2 Game Pad
HOW TO INSTALL BORDERLANDS ADD ON GAME PACK ORIGINAL GAME CD
You need to get a copy of either DOSBox or VirtualBox to help you play older games on your newer system. You can download them and learn about them from the links below.
Dosbox:
http://www.dosbox.com/
VirtualBox:
https://www.virtualbox.org/
Aug 18, 2012 | 2K Games Borderlands patch
Borderlands Pc Game not running. Please help.
Get the latest video drivers. Also you are short of 600 MHz to meet the CPU requirement
Nov 29, 2009 | Dell Vostro 1500 Notebook
Video Game Consoles & Games Logo
Top 2K Games Video Game Consoles & Games Experts
Dave
rhodesworks
Are you a 2K Games Video Game Console and Game Expert? Answer questions, earn points and help others
