Question about Canon imageRUNNER 4570 Copier
Paper comes blank when i copy in ir4570 - Canon imageRUNNER 4570 Copier
3 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Does not print has blank copy
Before you added toner was it working OK, but it was asking for toner? If so the problem may be simple. The Blue lever you pushed down and to the right to release the Developing unit, was it locked in at the Nine o'clock potion? Is it now at the Nine o'clock position now or is it in a different position now. If so make sure it is at the Nine o'clock posisition now and that the front door can close correctly. Good Luck
Posted on Apr 20, 2008
canontech
  • 1219 Answers
SOURCE: IR4570 paper jams at fixing unit whenever i try to
first clean all rollers espc. below the drum unit two rollers on axis, if the paper comes out bent in the roll open fresh pack of paper because of moisture, when you open the right door above fixing unit you will see one more small door that is loosen, on these inner door you will se long plastic flapper ( ussually black plastic with small picker fingers ) that is connected to solenoid, these flapper has on both sides some kind of sponge sticker on left and right space where it touch the inner door - REMOVE THEM.
Hope that helps!
For service manual write me on emma.servis@gmail.com
Posted on Sep 09, 2010
Paper jam?
my dear you change paper feed roler
Aug 06, 2015 | Canon ImageRunner 4570 | IR4570 |
Copy Machine is running ready but can't print and copy.
The paper tray is not placed properly leading to erroneous sensing place the paper trays properly
Jun 22, 2015 | Canon ImageRunner 4570 | IR4570 |
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
Jan 30, 2015 | Canon ImageRunner 4570 | IR4570 |
IR4570 Paper Jam on Duplex
" Re: iR4570 Paper Jam on Duplex Mode
IR 2270, 0108 & 0207 jams your code is the fuser sensor but I would think about adjusting the loop esp if the paper is coming from an optional lower cassette.
FIRST THING I would do is replace the pads for the flapper figure 140 item 6 in parts manual. the two black foam pads were changed to a stronger white pad. These can cause your problem.
The updated pad number is fc9-4659 you need at least two . Plus you need to make sure the metal cover is on your registration sensor. fc7- 9370 ." http://www.copytechnet.com/forums/canon/68195-ir4570-paper-jam-duplex-mode.html
Oct 11, 2014 | Office Equipment & Supplies
Ir4570 email
Sorry, wxygzgc, but there is no indication at all in the Users' Manual that the IR4570 has any email capability.
http://www.agercopy.ro/poze/24547_1_Manual%20Utilizare%20IR%202270_2870_3570_4570.pdf
May 20, 2014 | Office Equipment & Supplies
IR4570 paper jams at fixing unit whenever i try to make copies of A4 double seded. Legal is ok. problem repeats for every 6to8 copies after clearing the jamed paper.
Hope that helps!
Sep 09, 2010 | Canon Office Equipment & Supplies
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
May 21, 2009 | Canon Office Equipment & Supplies
Regards DADF size setting in ir4570
Are you sure the problem is not coming from the paper tray????
Open the paper tray and look at the guides that hold the paper, if Letter paper is in tray make sure the guides are set against the paper, also look "behind" the tray for paper it could be changing the paper size.
Oct 03, 2008 | Canon imageRUNNER 4570 Copier
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon imageRUNNER 4570 Copier Logo
old marine
old marine
