Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi milk frother knob broken - DeLonghi Coffee Makers & Espresso Machines
SOURCE: THE NESPRESSO MILK FROTHER HAS STOPPED FROTHING
I contacted Nespresso who may well replace the item
Posted on Nov 27, 2009
  • 21 Answers
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Posted on May 08, 2010
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Posted on Jul 01, 2010
  • 155 Answers
SOURCE: The milk in the frother
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Posted on Sep 14, 2010
SOURCE: My Nespresso machine is the
Have same problem with my Citiz
Posted on Oct 18, 2010
How can i fix the hot milk function on delonghi coffee machine?
The voice from the grinder ??
If so that's men you pushed the cappatino
Try to push the same button twice you will read
Further and steemar
Apr 06, 2015 | DeLonghi Magnifica Coffee Makers &...
No water coming out or milk coming out of spouts
This is a simple malfunction. Descale the machine one two or three cycles until the flow of water through the hot water pipe is with full jet.
The frothing will also be restored. If it does not, then you may need to clean the Milk stone clogging the frother. Milk stone is like cement and needs care and patience to clean without damaging the frother.
Good luck..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 17, 2014 | DeLonghi Coffee Makers & Espresso Machines
Changing the Magnifica ESAM 3500 milk temperature
This is preset and cannot be altered.. Do ensure you preheat the milk frother before use.. by activating the "clean" button on the frother jug
May 15, 2014 | DeLonghi ESAM3500 Espresso Machine &...
The descaling light stays on even though I have gone thru the process of descaling.
You are not completing the descale program. See below.
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over
time it is normal for the tubing inside the machine to fill with lime scale.
When the light starts flashing( chap. 12-point 5), it is time to descale
the machine.
NOTE: when the light switches on, the coffee maker can still be used to
prepare coffee.
Proceed as follows:
• Empty the tank and pour in the contents of one bottle (125 ml) of
DURGOL descaler plus one liter of water. For subsequent descaling
operations, descaling solution can be purchased from authorised
technical service centres.
NB: Make sure splashes of descaler do not fall onto surfaces sensitive
to acid such as marble, limestone and glaze.
• place a container with a minimum capacity of 1.5 litres under
the milk frother (Fig. 3);
• turn the machine on by pressing the button (Fig. 4).
• wait for the green and indicator lights to come on steady.
• press and hold the button for at least 5 seconds (Fig.14). The
light inside the button switches on (chap. 11 - point 8) to indicate
the start of the descaling program (the and lights remain
off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn anticlockwise (Fig.5). The
descaling solution will come out of the milk frother and start to
fill the container underneath.
• the descaling program automatically performs a series of deliveries
and pauses, so as to remove the lime scale deposits from
inside the coffee maker.
Fig.32
The two red buttons
have opened
out CORRECTLY
The two red buttons
have not
opened out
CORRECT INCORRECT
33
OPERATING INSTRUCTIONS
• after around 30 minutes, when the light comes on (chap. 12 - GB
point 1), turn the steam knob half a turn clockwise (Fig.6) until it
stops.
The machine must be rinsed so as to eliminate the residues of descaling
solution from inside the machine. Proceed as follows:
• remove the water tank, rinse it and fill it with clean water.
• reposition the tank.
• empty the collection container (located under the milk frother) that is
full of liquid, and then replace it under the milk frother.
• turn the steam knob half a turn anticlockwise (Fig. 5). Hot water will
come out of the milk frother and fill the container underneath.
• when the tank is empty, the light goes off and the light
comes on (chap. 12 - point 1).
• turn the steam knob all the way clockwise (Fig. 6) and fill the water
tank with clean water again.
• the program of descaling is hour terminated and the machine is
ready per do again the coffee.
NOTE: if the descaling procedure is stopped before completion, the
alarm (chap. 12 - point 5) is not deactivated and the procedure
must be started again form the beginning.
IMPORTANT: THE GUARANTEE IS NOT VALID IF THE ABOVE DESCALING OPERATION
IS NOT PERFORMED REGULARLY.
Sep 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Cannot ventilate machine
Sounds like the milk frother is blocked.
Remove the frother completely,try to ventilate without it.
You should be able to see through the center of the frother.
If not try to clean it out with a paperclip or pipe cleaner.
Dec 27, 2009 | Gaggia Titanium Espresso Machine
Frother not working
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Apr 19, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
21 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
