Question about Toro Lawn Mower With Toro Power Tools
Billows of white smoke when Toro lawn mower runs
I've changed the oil for this season. After the mower warms up it starts to send billows of white smoke from the front of the mower. Did I overfill, underfill oil tank?
    Scholar:
  • 81 Answers
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Posted on Jun 19, 2009
My toro fh 580v smokes when i start it what is causing it to smoke?
hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
May 16, 2014 | Toro Zero Turn Rider 74833 Lawn Mower...
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Smoking lawn boy mower
Check head gasket hopefully that is only problem.
Sep 25, 2017 | Briggs & Stratton Garden
White smoke billowing from front of mower
is the smoke from the exhaust?or just the front of the engine look for a oil leak from the head gasket
Apr 30, 2012 | Garden
Mower started to smoke then shutt off
did you tip it on its side to do the belt? does the oil smell like gas like the needle valve in the carb is not sealing
Apr 19, 2012 | Toro Lawn Mower With Toro Power Tools
White smoke comes out when I pull the cord.
Did you notice this after the engine oil was changed. If you overfill oil it will smoke. Check oil level. Let me know if this helped. I have other ideas, but this is the most common problem with smoking.
Jul 06, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air...
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck barterjoe_64.png
Mar 23, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
Lawnmower wont start
check your sparkplug clean or replace, also crank it several times without sparkplug in it to blow out the cylinder, did you have it on it's side for anything?
Jun 05, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
3,405 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
