Question about Reliance Water Heaters
Locating air intake screen - Reliance Water Heaters
  • Reliance Master
  • 5,089 Answers
Reliance is 3-leg water heater.
Air intake located on bottom of heater.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Gene
Posted on Oct 25, 2014
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
Apr 17, 2013 | Water Heaters
Reliance 606 propane pilot won't stay on when i begin to turn on.its like ite not getting the message or signal,HELP PLEASE
1) Reliance is AO Smith-American, and air intake screen located on bottom of water heater. Clean air intake. Replace thermocouple. First two digits of serial number are year of manufacture.
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Add comment and say what you tried so far.
Include age of water heater.
Jan 05, 2013 | Reliance & LP Gas Water Heater Control
Find filters on a kenmore miser 6 gas water heater
1) Are you looking for air intake screen located on bottom of water heater? Clean with compressed air or feather duster.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
2) Kenmore water heaters are made by AO-Smith/ American
Stand 3-legged water heaters are bricks so air intake is easy to clean.
Dec 29, 2012 | Water Heaters
How to take off the thermal couple off a ge sg40t12txk
1) Copy following links:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) GE is made by Rheem, so air intake screen is located below the combustion burner, as is the TRD (thermal reset device).
3) Modern gas water heaters, the FVIR, or FV system will trip when air intake gets clogged with dust.
This will slow venting of hot combustion gasses, except burner is still burning same amount of fuel. Overheating occurs, and that trips FV system.
Other brands require cleaning air intake screen and possible replacement of gas control valve, or FV sensor, etc. Each model is different.
Rheem_GE overheating will trip TRD, and glass vial breaks, causing air intake to close. Glass vial must be replaced, and possibly the gas control valve replaced.
Dec 18, 2012 | Rheem 36" Water Heater Thermocouple Kit
Propane water heater high limit switch keeps kicking out
1) What brand and model water heater?
Copy following link for troubleshoot by type of gas control valve.
2) Clean air intake screen using compressed air or feather duster.
With AO Smith, craftmaster, state, reliance, american, kenmore, whirlpool, the air intake is located on bottom of heater. Rheem, richmond, ruud, GE, Bradford white, the air intake screen is located under combustion parts.
Water heaters today require plenty of fresh air. If air intake gets clogged with dust, then combustion byproduct moves up pipe too slowly for amount of fuel being burned, and this overheats combustion chamber.
3) Add a comment with more information
Dec 13, 2012 | Water Heaters
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Have to keep lighting water heater
Clean air intake. Change thermocouple.
American Standard appears to be Bradford White or Rheem product from the one image that appears on the AS site.
Air intake located on side of unit funnels air to arrestor screen located under the combustion burner.
Remove burner and blow out screen with compressed air.
If this is Rheem product, then also inspect for broken glass vial that indicates high-temperature FV event, which might also require other parts to be replaced.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Sep 27, 2012 | American Standard 40 Gallon Natural Gas...
How to clean air intake screen on kenmore power miser 6 hot water heater
Kenmore is AO Smith.
Set this brand water heater on bricks for ez access to arrestor screen located on bottom.
Air intake located on bottom of unit, and should be accessible without removing combustion parts. Use feather duster, or compressed air.
Copy following links for specific illustrations and information:
Same information also shows in product manual .... and you didn't save that, but next time for sure.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 17, 2012 | Water Heaters
Where does air enter a new style gas fired water heater ? how do you clean the air intake area
Air intakes vary by brand and model.
Product manual has complete information for air intake, and yearly burner cleaning and maintenance.
1) You posted under Richmond heaters which is Rheem
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
For a manual, click on your product and next page has documents that download to your computer, including care and use manual.
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
Sample manual shows air intake is a grille located on side of tank.
Intake should be kept clean, and water heater never placed in room with dust, link or chemicals. Even trace chemicals will react with burner and prematurely corrode burner parts.
2) If you have Bradford White water heater, air intake is on side of tank through louvers.
3) If your gas water heater stands on 3-4 legs, then air intake is located on bottom of tank, making it difficult to clean unless tank is sitting on bricks.
Here is photo of air-intake screen on bottom of Whirlpool tank.
Tomorrow this heater is scheduled for installation, and it will be put on bricks.
On this specific model the front cover can be taken off, the burner cleaned, and cover put back on using same gasket, and without buying parts.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water heater pilot keeps going out. Relight and may stay lit for a day and then goes out again. Now won't even light at all. Has an igniter button. Also says to clean intake screen every 6 months. Where is...
the intake screen or as is called flame trap is located on the very bottom of the heater underneath. this is very important that you keep this clean or it will keep going out. this is the only way this heater has to get air to the burning chamber.
Nov 23, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
70 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
