How many quarts in a pound - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
That depends on what you have. A quart of water weighs about two pounds. A quart of molten gold will weigh about 27 pounds.
Posted on Apr 21, 2014
Tip
2007 Jeep Grand Cherokee Fluid capacities
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION SPECIFICATION FUEL TANK
All Models
76L (20 U.S. Gallons)*
ENGINE OIL
3.0L Diesel with Filter (10.0 Quarts)
3.7L with Filter (5.0 Quarts)
4.7L with Filter (6.0 Quarts)
5.7L with Filter (7.0 Quarts)
6.1L with Filter (7.0 Quarts)
COOLING SYSTEM
3.0L Diesel
13.2L (14.0 Quarts)
3.7L (9 Quarts)**
4.7L (14.5 Quarts)**
5.7L (14.5 Quarts)**
6.1L (14.8 Quarts)**
A/C REFRIGERANT SYSTEM
All Models
0.68 kg (1.5 Pounds)
POWER STEERING SYSTEM
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 545RFE
2WD 5.2 L (11 Pints)
4WD 6.2 L (13 Pints)
Service Fill - NAG1
5.0L (10.6 Pints)
Overhaul Fill - 545RFE
13.33L (28.0 Pints)
Overhaul Fill - NAG1
7.7L (16.3 Pints)
TRANSFER CASE
NV140 and NV146
0.65L (1.4 Pints)
NV245
1.8L (3.8 Pints)
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
on Jan 04, 2011 | Jeep Grand Cherokee Cars & Trucks
What equals 48 ounces??
Hi Yesenia
There are a couple of possible answers, depending on whether you're talking about liquid ounces, or weight ounces.
For liquids, there are 8 fluid ounces in a kitchen '1 Cup' measuring cup. That means 48 fluid ounces are the same as 6 cups, 3 pints (2 cups per pint) , or 1-1/2 quarts (two pints per quart).
For weight, there are 16 ounces in a pound. (One fluid ounce of water also weighs one weight ounce, which is the basis of the adage 'A pint's a pound, the world around', since a pint is 16 fluid ounces, and 16 fluid ounces of water, or near-water like some beer, will then weigh a pound' ).. Anyhow, in this case, 16 goes 3 times into 48 ounces, so it will weigh 3 pounds.
For metric, 2.2 pounds per kilogram, or 29.5735 milliliters per fluid ounce.
Cheers!
Nov 18, 2015 | Office Equipment & Supplies
What is the right oil and filter to use on the range2007 hse?
How To Change Oil and Oil Filter on Range Rover Sport or Land Rover LR3
  • Place an oil drain pan below the oil filter and drain plug and unscrew the oil filter.
  • Lubricate the rubber seal with clean oil and install the new filter. Tighten to 13 foot-pound torque.
  • Remove drain plug in the oil pan and drain the oil. Catch the oil in the drain pan. After draining the oil install and tighten the drain plug to 18 foot-pound torque.
  • Fill engine with 5W-30 weight oil. The 4.4 V8 takes 8 quarts; the 4.0 V6 takes 6 quarts. Start engine and check for leaks.
  • Recheck level and top up as necessary.
  • Reinstall the under engine shields / skid plates.
Apr 12, 2015 | Land Rover Range Rover Cars & Trucks
How many pounds in a quart; I have a 2 quart scoop for horse grain and need to know the equivalent amount of lbs that it would equal
You would have to weigh it sweetheart. Every type of feed contains different ingredients. Different ingredients have different weights.
Feb 12, 2015 | Cars & Trucks
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
Jun 28, 2014 | Health & Beauty
1.0 dozen oranges has a mass of 9.0 pounds. if the volume occupied by 6.0 oranges is 2.0 quarts, find the volume of 25 pounds of oranges?
9lb/12 oranges= .75 lb/orange
2qt/6 oranges=.33 qt/orange
25lb oranges/.75 = 33.33 oranges
33.33 oranges x .33qt/orange = 11 quarts
Feb 26, 2010 | Educational Insights Hows and Whys Of...
How many pounds of sloppy joes can I fit in my five quart crock pot?
Well, that all depends on how dense a sloppy joe mixture you make. If you add pounds and pounds of ground beef to the mix and just the sloppy joe sauce, then it would be many pounds.
But as for a good rule of thumb, "A pints a pound the world around" In other words, if you're making sloppy joes from the pre-mixed cans, just weigh one 16 oz (1 pint) can and that's 1/2 quart.
If you're making it yourself, we're back to the whole density of your chosen ingredents.
However, I've done a little research for you and based on the density of cooked beef and converting the weight of that cooked beef into the 5 quart volume of your crockpot, I've come up with the following info for you.
Cooked Beef has a density 129.52 Ounces per Gallon (a technical measurement)
So based on that data (not including your sloppy joe seasoning/sauce and other add-ins), you should get approximately 10.12 Pounds of Sloppy Joe Mixture to fit into your 5 Quart Crockpot.
I would guess that the amount would be just slightly less, since you might want a little room for putting on the lid, etc., but you should get around 10 Pounds to fit easily in your 5 quart crockpot.
I hope you find this Very Helpful and best regards!
Nov 19, 2009 | Rival 38501 Smart Pot 5-Quart
106 people viewed this question
jasbo
jasbo
