Question about Honda Garden
No drive honda FG 201 - Honda Garden
What is the dry weight of a 2009 2605 seaswirl
Hey Bill, NADA does not list a 2605 for 2009..
is this an outboard or stern drive..
2009: 2301 WA STRIPER 24' STERN FG 1 220 4450 8'6" Gasoline 2301 WA STRIPER(**) 24' OUTBD FG 1 200 3850 8'6" Gasoline 2601 CC STRIPER(**) 26' OUTBD FG 2 150 4250 8'6" Gasoline 2601 WA STRIPER 26' STERN FG 1 270 5150 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 2 150 4550 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 1 225 4550 8'6" Gasoline 2009 Seaswirl Boats Prices Values
Jun 05, 2017 | Boating
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
model was launched 1998
replace the timing belt sounds logical
take photos of how the crank and valve cam cogs line up before replacing the timing belt
Honda FG110 ROTOTILLER USA VIN FAAA 1000001 TO FAAA 1199999 Parts Diagrams
Where to connect the throttle cable on a GX 31 honda motor FG 100 tiller
I look up honda engines at : honda-engines-eu.com they have the best access to detailed information. If you can identify the carb butterfly, any cable should attach to the butterfly control. I see a Honda GX100, but not a GX31.
Oct 09, 2012 | Honda Horizontal OHV Engine 340cc, GX...
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Oct 10, 2009 | Honda 25cc 4-cycle Mini Tiller
Jhdfn dfn
are you sure its not nh fg f fdhn ?
I think you need to fdh jdyfdhdfg to fix it
Aug 13, 2009 | Dell (UD295) 80 GB Hard Drive
Honda fg 1oo won't start
It can be fixed take it to a small engine (lawnmower) shop
May 20, 2009 | Garden
Dethatcher pins on my accessory for the honda FG 110 are broken
MANTIS TILLERS USE THE SAME ATTACHMENT CALL THEM @1 (215)355-9700
Jan 29, 2009 | PDP Systems Dethatcher Attachment for...
Garden Logo
24 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
