Question about Samsung HP-R5072 50 in. Plasma HDTV
Image is grany every time tv is cold.
Hi:
When I first bought the TV the image was crispy and clear at all times, now I have to let the tv warm up before the image is clear again, if the tv is cold, most of the screen get grainy and parts of the images slowly fade away for a few seconds after the image has change, after 10-15 minutes of the tv being on, it fixes it self, but It has become very annoying to have to wait until the image is back to normal every time I turn it on before I can watch a movie, any suggestions on how to fix this?
  • er_chap0124 Nov 02, 2007
    forgot to say its a samsung hp-s5033
  • er_chap0124 Nov 21, 2007
    thanks, after finding the warranty called samsung, the tech came 48 hours later, did what you had describe and that fixed it. very simple and stright forward fix too.
I had the same problem. Except mine never got better after the tv warmed up. I fortunately I still have my manufacturers warranty and Samsung sent a guy out within a few days. He replaced a few parts which really didn't do anything. However what he did that was interesting was on two circuit boards. One on the mid left and the other on the mid right. Apparently there is a nob or something he tweaked on each panel that cleared the grainy image right up. What he told me was that the it is basically pixels that are not turning off in sync. adjusting the two circuit boards syncs the pixels to turn on and off at the same time.
Posted on Nov 12, 2007
LCD TV - INTERMITANT BLUE SCREEN
Fault in the main board. You have to replace the main board. As it's have SMD components is would be difficult to repair.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 13, 2016 | LG 37LC7D 37 in. LCD HDTV
Zenith IQB32B42W 32" TV works sometimes but looses picture. Top half of picture goes blank (dark) and the bottom half scrambles into horizontal lines. I hear a pop or click right before this happens. The...
Capacitors can be deformed or some solderings on active components can be bad.
Amplitude change and image geometry want change when warming up, buy a canister cold spray and spray some components, Be careful when working at high voltages in the fly-back (horizontal) circuit by crt television, and tripler and Focusing voltage.
Aug 11, 2017 | Zenith IQB32B42W 32" TV
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Red and green ghost images on screen. usually appears after tv is warmed up. TV is 8 years old. Is it worth repairing? How much to repair? I have read that it may be problems with convergence chips.
Since the problem comes on with the set warmed up the most likly cause is cold solder joints. This happens because componets heat up and cool down at differant rates and over time cause the solder conectin to break or become intermitant. The simple fix would to get the convergance IC's soldered and while in there solder up the entire high voltage section
Dec 18, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv takes a long time to warm up. after 20 min. picture still distorted.
havent a clue normally only answer car questions,but if its one of them projection things then if its anything like the ones in our local bars then they have all chucked them and bought a flat screen with built in digital tv for the football on the spanish tv .Because they have all had similar problems to yours with them ,long time to work and fuzzy images and when you have a lot of scotsman and they cant see the ball you will understand why the english ended up with so many colonys ,Their violent
Nov 10, 2009 | Toshiba 42H81 42" Rear Projection...
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
I have philips plasma tv model #42PF9630A with ambient light
last time I had seen these syptoms on Philips plasma it was bad panel. Replace tv panel is too expensive to replace.
Aug 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Image is grainy whenever tv is cold
try having the v_set and v_scan voltages reset 15vdc lower..
Nov 02, 2007 | Samsung HP-S5053 Television
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Samsung HP-R5072 50 in. Plasma HDTV Logo
181 people viewed this question
Jerry Greenberg
Jerry Greenberg
