SS-ZUX10D connectors Need clips for the back of unit for speckers
How to repair SONY HCD-ZUX10D DVD DECK RECEIVER always display EJECT and then STANDBY ?
https://community.sony.co.uk/t5/home-cinema-projectors-players/how-to-repair-sony-hcd-zux10d-dvd-deck-receiver-always-display/td-p/2295791
Aug 21, 2017 | Sony Audio Players & Recorders
Can't get speckers to work on a new panasonic radio in a 96 ford ranger
check the plug connectors are the right ones for the radio maybe you need to fit more earths to the connectors
Mar 12, 2012 | Car Audio & Video
My sony LBT-ZUX10D midi hifi system disc tray doesn't open, and it writes error code C 31 00. i opened the top and brought out the discs that were stuck inside and still it doesn't open.
This can be due to many reasons and for a start you must be able to check the power to the loading motors, the loading drive IC's. If there is no input command to the IC,- check the voltages before eject , play is pressed and on rest.- to compare and confirm a input loss. If so the processor controller section is a suspect. Also if the mode settings are out of sync , the loading will not work.
Cannot rule out a damaged mechancial link, gear or drive. Need to start checking with all these tips after the mechanism is removed.
Take care with connectors and connections, make a note of your working so as not to forget the sections when fitting back.
Oct 08, 2011 | Audio Players & Recorders
Amp powers up red then turns green for a few seconds then shuts off power alltogether
My specker was working fine then the am went to on protection mode and backs power mode but my specker doesnt work but on when my volume is low
Sep 23, 2011 | Kicker (ZX750.1) Car Audio Amplifier
Dishwasher won't drain or seems to drain to other diswasher.
possible blockage at sink pipe where the drain hose connects to. the drain hose is attached to the spout on the pipe. remove the clip holding the drain hose to the spout, remove drain hose gently, put drain hose into a bucket and then turn unit on to a cycle. it should start draining straight away.if it does drain into bucket u have a blockage in the spout. put a small screwdriver into spout to unblock . then put drain hose back onto spout with clip and run a cycle. before i forget when and if the water starts draining into the bucket turn off the unit so u can put the drain hose back on. if u need more help please reply. good luck.
Apr 27, 2010 | Fisher and Paykel 23 in. DD603H SS...
Jvc dvd cd player 3in monter
Was it working before?
If so, (a) fade control is not in the center or (b) Unit or speaker is broken
If it never worked, then check wiring
Jan 27, 2010 | JVC KD-AVX1 Car DVD Player
How do i wire in a Zn-4088 Xlopd sub/amp?
I also bought one and it came with no instructions either.
Should be pretty simple but if you want to control the On/Off of it by the head unit you will need to use a relay,
Sep 24, 2009 | Car Audio & Video
No sound coming from speckers after restoring computer
You haven't reinstalled the drivers for your sound device. If it's a Dell, you'll either need the Blue/Gray CD that came with the computer labeled "Device Drivers", or go to support.dell.com enter your service tag #, and select "Drivers", and download drivers for sound.
gurutim
Mar 21, 2009 | Audio Players & Recorders
Miele G661 Dishwasher heating element
Loosen element-retaining bolt plus clips in dishwash chamber. Upend machine and take base off (held by four crosshead screws). Disconnect spade connectors from end of element and gently tap/push old rubber block through. Element will drop out with retaining rubber.
Hautebrian.
Mar 06, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Open Questions:
11 people viewed this question
 Grubhead
Grubhead
