Question about Thermos 6000 Traditional Grill
Manual for thermos grill 463322013e
Thermos 3 burner gas grill mn 463322013
burzerko
  • 254 Answers
SOURCE: Thermos Gas Grill
This is caused by a bad regulator. This is the silver device that usually attaches directly to your tank. Most hardware stores carry these regulators you will need the numbers off it to match up a new regulator for size.
Posted on Jun 25, 2008
SOURCE: thermos grill-to-go.
found thermos website which I was unable to do previously. Thank you.
Posted on Jan 31, 2009
  • 291 Answers
SOURCE: I have a natural gas line being run to my deck.
If your grill is designed for propane, it will probably work with gas, but the BTU output will be lower. You can buy parts to convert, but unless your grill was sold as being duel fuel, it will void any warranty from the manufacturer. If it was duel fuel, it would have been marked as such on the paperwork that came with it. I think Thermos even has a special symbol on them.
Posted on Aug 26, 2009
bulldogchief
  • 388 Answers
SOURCE: converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Posted on Nov 20, 2009
  • 30 Answers
SOURCE: a burner knob somehow melted off and now when I
You may have a blockage in the tubes connected to your gas valve. It could be a spider web.
The burners may not be connected to the valve properly.
It could be an overfilled propane tank, and the overfill protection kicked in.
It could be a bad regulator.
Posted on Mar 10, 2010
I have thermos quick set gas grill--are the lava rocks supposed to cover the burner cover
They should cover the tray above the burner so the burner can heat them .
Apr 20, 2012 | Thermos Quick Set Gas Grill 4000
How does the burner connect to the regulator for the thermos Millennium 4000
In most grills, the burner is "seated" on the valve, the valve is attached to the manifold, and the manifold is connected to the gas hose and regulator.
Jul 02, 2010 | Thermos Quick Set Gas Grill 4000
I have full propane, yet a low flame?
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
May 15, 2010 | Thermos Stainless Steel Gas Grill
Not enough flame and when i change the settings
it sounds like the reg off the gas bottle or blocked burner
May 15, 2010 | Thermos Grill2Go Gas Grill 4656110
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
Cracked primary burners
yes call Flame Grill Services at 770-521-2050
Mar 18, 2010 | Thermos Stainless Steel Gas Grill
A burner knob somehow melted off and now when I try to light the grill it barely keeps a low flame. Is it a regulator problem? I have a Thermos gas grill with three burners-about 3 years old.
Mar 07, 2010 | Thermos Grilling
This is for the Thermos Millenium 4000: I need
Ive replaced the gas tank and make sure valve is on tight but the flame is still weak!?
Feb 01, 2010 | Thermos Quick Set Gas Grill 4000
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Thermos 6000 Traditional Grill Logo
95 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
