Question about Boating
Motor was running just fine and just quit power is there but no responce
Sears diehard 25lb thrust
2 Suggested Answers
  • 8 Answers
SOURCE: motor won't run
Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
Posted on Nov 28, 2008
Do I have a negative battery system or positive battery system?
If you have a 12volt standard electrical system in your vehicle.
It is both positive and negative. The travel inverter converts this 12 volt DC current into 110v 60hz AC current so you can plug in your electronics that require standard household current to charge/operate.
There is a built in USB port if you device will accept this for 12 volt power. It also has the power oultet with ground for 110v 6hz power.
Link below has a good picture and description. Hope this helps!
http://www.sears.com/diehard-120-watt-ultra-slim-travel-inverter-with/p-02871520000P
Dec 30, 2013 | Sears DieHard 120Watt Ultraslim Travel...
Alternator 0%; battery not holding charge
Not sure I follow you. Nothing should be on at night with the key switch off.
If something is on or there is a short in the system, the battery will drain overnight.
And have you had the charging system checked on the truck ?
It should be charging 13.8 volts or more with the engine running.
Aug 08, 2013 | Jeep Cars & Trucks
I have a 2004 PT Cruiser Platinum series with a 2.4 liter engine, wjhat is a suitable replacement battery for this car; Sears die hard or interstate ?
Sears Diehard or Interstate would make a battery for your vehicle. Look for something with over 600 cca and you should be ok for the winter.
Diehard makes a Platinum battery, but it costs over $189.99.
Diehard Gold batteries are like $109 or so.
Walmart sells batteries that are comparable to the Diehard Gold for under $100.
However, I just bought a Platinum battery for my 1997 Cadillac Deville Limo and it seems to work alright so far and has a 4 year free replacement warranty.
In general, the more you pay, the better the battery up to the 'best' which is the Diehard Platinum.
Walmart and Interstate do not offer a battery that has as long of a warranty or as good of a design as the Platinum from Diehard which uses proprietary technology to get a better warranty than normal.
The Platinum name in the PT Cruiser has nothing to do with the Platinum name for Diehard, by the way.
Good luck on finding a suitable replacement battery for your 2004 PT Cruiser Platinum.
Nov 18, 2010 | 2004 Chrysler PT Cruiser
What's the best battery for a caddillac deville
I put a Diehard Platinum battery in mine for about $189.99 plus tax at Sears Holdings or Sears for short.
It has a 4 year free replacement warranty, the best in the business, and has higher cca's than the Gold version of the Diehard which is equivalent to the best that Walmart sells.
Good luck on buying the 'best' battery for your Cadillac.
Nov 02, 2010 | 2002 Cadillac Deville
NO RESPONCE-NOTHING - DEAD - CHECKED WIRES -KODAK ESP-3-WAS WORKING FINE, JUST QUIT.
take power cable and usb cable out of the printer .hold down the on/off button for 40 seconds without cables. then plug power cable and restart ur printer. make sure the green light on end of power cable is on. contact kodak @ 1800 421 6699 for further issues
Jul 26, 2009 | Kodak Office Equipment & Supplies
Eflite 60amp esc - no throttle responce
Lower throttle trim all the way. It will arm like a charm.
Cliff
May 23, 2009 | E-Flite 60-Amp Pro Switch-Mode BEC...
Motor won't run
Sep 02, 2008 | Boating
Wiring diagram for Die Hard 28 lbs thrust trolling motor
It's probably a Minn kota with a die hard label. Call Minn kota and ask them.
Aug 08, 2008 | Boating
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
