Question about Rheem 75 Gallon NGAS Water Heater PWR VENT 6YR 22VRP75
Temperture pressurrelief valve how to replace
Gas oven dosen't maintain set temperture
My experience on the direct spark ranges is that the gas valve is usually at fault for this problem. The regulator valve and the burner shutoff solenoids are all built together in one valve assembely. The valve will work properly until it gets hot then it will stick and not open when the oven calls for heat again.
Please post back with the complete model and serial numbers if you need further help in troubleshooting it. There have been many updates and design changes on these ranges.
Thanks/Mike
Oct 28, 2007 | KitchenAid KGRS807SSS Gas Kitchen Range
1993 dodge caravan heater problems
There should be a vac controlled valve on the heater hose near the firewall. If that valve fails, or something happens to the vac source, the valve will not open or close. I would check that valve and make sure it is working. Both heater hoses should be hot when the engine is warmed up.
Dec 08, 2012 | Cars & Trucks
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
Troubleshooting no. po118 po705 po301 i need to
P0118 - Engine Coolant Temperture Sensor - Circuit High Input
P0301 - Cylinder 1- Misfire Detected
P0705 - Transmission Range Sensor Switch Circuit Malfuction (PRNDL Input)
P0118 - Replace Engine coolant Temperture sensoe located by thermostat housing (upper ragiator hose connects to) sensor is 1 where wire loom lays nect to valve cover.
P0301 - bad spark plug/wire, remove #1 cylinder plug wire inspect for oil on wire (if have oil on wire, valve cover gasket leaking, needs to be replaced) if no oil, inspect plug, replace plugs if needed.
P0705 - bad neutral safty switch (Transmission Range Switch) located on Right Side of Automantic Transmission (by shifter cable)
Feb 09, 2010 | 1998 Kia Sportage
Temperture is loosing
daer sir
I have solve my problem.now fryer is working properly its temperture is ok .the problem was in gas valve .thx
nbassociates
Dec 26, 2009 | Pitco Frialator Kitchen Appliances -...
AWD Light stays on
3rd dealer stated that the problem was in the differential pump valve, when the temperture sensor was giving a false reading and disconnecting the rear wheel drive. Replaced with GM Part 88896067, and it solved the problem. Mechanic stated that if it is ONLY the AWD light, then this is usually the problem. If the ABS Disable light also goes on, then it is the harness on the wheel sensor.
Jul 28, 2009 | 2002 Buick Rendezvous
Heater permanently on hot - temperature control has no effect
yhe temperture control valve is jammed and will need replaced
Jul 11, 2009 | 2004 Ford Focus
Rheem 75 Gallon NGAS Water Heater PWR VENT 6YR 22VRP75 Logo
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
