Question about GPS
Garmin 1300 running very slow
Garmin is running very slow. it takes 5 to 10 minutes to load maps and icons.
jonniewalker
  • 1031 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
  • 17 Answers
SOURCE: garmin 1300 stuck on maps loading frozen
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
Posted on Apr 16, 2010
  • 589 Answers
SOURCE: my garmin nuvi 1300 shuts
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Posted on Nov 12, 2010
  • 1514 Answers
SOURCE: My garmin nuvi 1300 keeps
There's a solution to your problem at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
The article deals with all possible reasons for there being no map data available but if your satnav is working other than that it may be just that the map is not selected. If you can get into the menus first try selecting the map by
pressing TOOLS
then SETTINGS or LOCALE on models that don't have a settings menu
Press MAP and then at the bottom of the screen press MAP INFO
Your map name should be there and a box with a tick beside the name.
If the box is not ticked press on the map name and it will cause the tick to appear. This might solve the problem. If not the map is probably locked. You'll find details of how to unlock the map at the above link.
Posted on Jan 06, 2011
  • 1043 Answers
SOURCE: My garmin 1300 says no
Your map file may be corrupt. You can go to the Garmin website where you registered your unit, and download the same map. If you want to update to a newer map you can do that as well. To ensure that you have the correct map you will have to register your unit if you haven't already done so. Go to the following link:
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
You will have to first make sure that your GPS is attached to your computer with the black USB cable that came with your unit. Plug the smaller end into the back of the unit and the larger end into one of your USB ports. The GPS will automatically power on. You will see a graphic on the bottom of your screen that looks like a GPS connected to a computer. A line will appear halfway up the screen which will start as a white line and then change to a green one. Once that is done you can register at the above site. The website will attempt to connect to your GPS so that it can read your model and serial numbers. It will then show you which maps are available for you.
Posted on Mar 13, 2011
The garmin nuvi 1300 series comes on and then says loading maps and does it over and over and will not load maps
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
1300 nuvi screen comes up loading maps and stops
I hope that helps.
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
After 5 minutes the unit turns off by itself. Need to stay powered down for a while to start back. Works 5 minutes...or less and then again.
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin 1300 says no detail maps found gps wont work with out it
I hope that helps.
May 09, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin will not load maps
A Garmin Nuvi 1300 that won't start, or freezes on 'loading maps,' is symptomatic of having corrupt firmware.
I hope that helps.
Mar 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin 1300 series will not load maps, it
I hope that helps.
Feb 28, 2010 | Garmin nuvi 1300 Car GPS Receiver
When i power it on it says loading maps and will not do anything
I hope that helps.
Feb 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin 1300 locked up and computer and 1300 will not recognize each other. I first download the latest updates and now the 1300 will not recognize the computer and there is not icon showing the 1300 and...
I hope that helps.
Jan 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
Screen frozen up on loading maps
I hope that helps.
Jan 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
