Question about Maytag 30 In. Stainless Steel Over-the-Range Microwave - MMV4203WS
My Maytag microwave model mmv4203ws is telling me to open and close the door. I do that and it keeps giving the same message. What is worng?
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Posted on Nov 23, 2008
  • 686 Answers
SOURCE: UMV1152BAB Maytag Microwave ... door look
REMOVE THE CABINET(COVER) AND YOU SHOULD BE ABLE TO SEE WHAT TO DO.
Posted on Apr 18, 2009
ironman89
  • 60 Answers
SOURCE: I have a Maytag microwave MMV5207 - we were using
sounds like the switch broke.your going to have to be creative and like ...tape a toothpick in the hole just right. or something
Posted on Sep 07, 2009
joeguest2
  • 2080 Answers
SOURCE: My microwave Maytag Model MMV4205BAB
Make sure your microwave is fully cleaned out of any old dried food residue and that you are not using any kind of metal items in your microwave when you cook because this will certainly cause smoking and sparking inside your microwave.
Most like you had some corrosion or food particles stuck to your WAVEGUIDE COVER PLATE.
Here is a link to a short video that show you exactly how to replace the wave guide cover yourself:
http://www.youtube.com/watch?v=M0xsXjhefy4
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the video at the website indicated.
Thank you very much and good luck
Posted on Apr 19, 2011
My microwave keeps telling me "Food" and will not turn on or heat anything.
if opening the door and closing it again wont clear this message, you have a door switch fault that will need to be repaired by a appliance tech
Feb 09, 2016 | Microwave Ovens
Maytag microwave model mmv1153baw light won't shut off and won't start
Either the latch in door (spring related) is not in the correct location or you have a door switch issue and its not expensive to fix if you husband is handy. Part number you can use is 28QBP0495 or the factory one 3405-001034 (more expensive). This issue is common and these switches are located inside the control panel on the left side, the switch you seek is the lowest one in the bracket of three. Good Luck and I hope this helps.
Apr 20, 2014 | Maytag Microwave Ovens
Can't get microwave to start
You likely have a bad top or bottom door switch or its mount is loose, misaligned, or broken.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can order parts for most major brands from the Pros here.
Jan 05, 2014 | Maytag MMV4205 Microwave Oven
Maytag microwave going crazy
< - Let ME know your full model number from the tag and I can give you complete detailed instructions on how you or a friend can fix it.
"SE" means you have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Jan 05, 2014 | Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Power comes on but at the end of the cycle nothing is cooked
Please check the door safety interlock switches. These are the micro switches inside the case that tell the oven the door is closed. When you open the door while the oven is running, there is an arc on the contacts in the switches and they burn a little. After a while, the switches are no longer able to report the door is closed. When the door is not closed, the heat is not turned on. Forget what you know about the door being closed.
Check the switches.
Thanks for your question at FixYa.com
Feb 20, 2010 | Maytag MMV5000 Microwave Oven
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Maytag 30 In. Stainless Steel Over-the-Range Microwave - MMV4203WS Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
