Question about Car Audio & Video
I have no volume on my tibo audio T1-200 stereo receiver
I have sound but no volume from the tibo audio t1-200 dab stereo receiver
3 Suggested Answers
SOURCE: volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Posted on Jun 26, 2009
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Kenwood ka 127 volume
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 04, 2012 | Audio Players & Recorders
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
My Sony stereo receiver LBT-D159 is not working properly, does turn on, make a click sound when turn on volume, but get no sounds, also CD player does not recognize any disc
My audio in wont work when connected to my note note book pc,it worked fine about 2mons ago, ive even switched audio in cords and still nothing. Both my music on my pc and stereo wok seperatly but wont when connected HELP!!!
Nov 08, 2010 | Yamaha HTR-5930 Receiver
Turned stereo on and turned volume all the way up and could just verly hear it comeing out of the speakers
assuming same issue does not happen if you connect a headphone to your receiver - can you check your speakers' connections - it should be straight not crossed for each and in case speakers are properly connected to your receiver - can you test the audio/sound with internal test audio rather than connected device (ie player) - if this is ok and there is no sound/audio volume settings on connected device - change the input the device connected and test again.
Sep 01, 2009 | Pioneer VSX-456 Receiver
No volume
bEFORE i CAN HELP YOU I NEED TO KNOW WHAT 'UNIT' MEANS. IS IT A STEREO RECEIVER OR WHAT. WHENEVER I TURN ON A STEREO RECEIVER AND HAVE NO SOUND ITS USUALLY POINTS TO THE FUSES IN THE BACK. ONE OF THEM IS BLOWN. IT COULD BE THE SPEAKER CONNECTION BUT I DON'T KNOW WHAT KIND OF UNIT IT IS.
Apr 10, 2009 | Denon DRA-685 Receiver
Audio volume control problem
Have exactly the same issue, no cure however
Mar 16, 2009 | Audio Players & Recorders
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
