Question about Dishwashers
Maidaid halcyon error 4 - Dishwashers
Maidaid dishwasher is in safe mode how do I change this
it may vary depending on the model number. if you google "maidaid dishwasher xxxx manual" where xxxx is your model number you can find the manual that should tell you how to fix that issue.
Apr 01, 2016 | Computers & Internet
Compressor thermister error
You will need to replace the compressor thermistor which is just a temperature dependent resistor - a wire going to a metal tube about 1 inch long. They usually come as an assembly of several of them that terminate at a single connector and plug into the controller board. Should be cheap to obtain and fairly easy to install. just make sure power is isolated for 10 mins before exposing any circuit boards.
Dec 09, 2015 | Fujitsu ASU12RLS Halcyon Ductless Mini Air...
The green operation light keeps blinking. I've reset unit and it still blinks
Could u explain more about this error,how many led light,flashing ??? Brand???model???
May 08, 2015 | Fujitsu HALCYON ASU24CL1 Wall Mounted Mini...
The red is blinking 8 times and green 4 times. The error charts states PFC circuit error. How can this be fixed ?
Power off at the isolator for 10 mins then switch back on and try again. If error code persists, then it is most likely the controller in the outdoor unit.
Excessive voltage of DC voltage on PFC circuit in inverter PCB is detected, or the excessive current in the circuit is detected.
> Permanent stop.
[Diagnosis Point]
Controller PCB defective (Refer to after mentioned "PFC circuit diagnosis")
Mar 21, 2015 | Fujitsu 15RLQ Halcyon Wall Mounted Mini...
HOW DO I FIX FUJITSU AOU24CL1 SERIAL SIGNAL (REVERSE) ERROR, AT OPERATION STARTUP
Outdoor controller circuit board sounds faulty. This error means that the indoor and outdoor units cannot communicate. Replace the outdoor controller in this case. Check if there are more than one outdoor PCB as others can be damaged as well.
Jul 25, 2014 | Fujitsu HALCYON AOU24CL1 Mini Split...
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Apr 18, 2013 | Fujitsu 30CLX HALCYON Wall Mounted Mini...
AC unit
You should post this question in the air conditioner section so the proper experts will see it.
Sep 05, 2012 | Fujitsu Halcyon ASU9RMLQ Mini Split Wall...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
