Question about Vacuums
Removing cover to replace belt vax power 1 upright
5 Suggested Answers
wayneard
  • 1901 Answers
SOURCE: hoover upright model u5095-930 belt change
I couldn't find your specific model but this may be similiar to another that you have to position the new belt around the agitator (beater bar) on the bottom of the vacuum, replace the cover, and then turn the vac over and remove the TOP cover to lift the new belt up and place it on the motor shaft/pulley. The new belt may require some effort to pull it over the pulley.
Hope this helps.
Posted on Oct 29, 2008
  • 86 Answers
SOURCE: Kenmore Upright Model 116.356224400. Belt
A picture is worth a thousand words, so the diagrams in this manual should be helpful:
35622 Owner Manual
Posted on Feb 08, 2009
Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
How do I get into the belt ?
unplug the cleaner,
tip in on its side and look underneath.
usually there is a bar that has to be lifted open. then you can see the belt. depending on model you may have to use tools to remove the brush roller to replace the belt.
I hope this was useful.
Oct 25, 2011 | VAX Appliances Vax X5 Bagless Upright...
I think I need to check yhe brushes on vax swift 1500 bagless how do I get to the motor taken some screws out nothing budged and now come to a standstill . Help please
If it's like my model, remove the top cover of the base unit (surrounds the hose connector), remove the drive belt underneath, remove the upright unit from the top of the motor housing. Hopefully, now the motor is just sitting there held by the swivel mounts. Using just your hands, pull back on the motor while pushing the housing away from it on the drive shaft side. This will allow the drive shaft to come free from the housing and the motor will then lift free.
Dec 28, 2009 | VAX Appliances Vax X5 Bagless Upright...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
How do i change the belt on my Vax V-015 06w46
Remove the two screws from the top cover, remove top to expose belt & replace. Replace top cover.
Jun 20, 2009 | VAX Appliances 2000 Canister Vacuum
HOw to change the Belt on a Vax VX1 Model
There is a brush reset button on the handle. Check to see if this has been pushed in. Also check to see that the brush slider has also been switched on. Usually belts are protected on this model but you should be able to remove the bottom sole plate where the base of the vacuum is (and beater bar). If the belt cover can't be removed then it has to be repaired professionally.
Mar 24, 2009 | VAX Appliances Vax X3 Bagless Upright...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
