Question about GE Profile DPVH880EJMG Electric Dryer
Runs for 5 seconds and turns off
Runs for 5 seconds and turns odd
Is it normal for the fuel pump to run when engine is running, It makes a buzzing sound
if the pump runs continuously after the ignition has been turned off, then the pump is malfunctioning. Some after market pumps do make odd sounds, unlike the factory original.
Dec 22, 2012 | 1998 Dodge Avenger
Sanyo PLC-XT10A shuts off after 30 seconds
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Dec 08, 2012 | Sanyo PLC-XT10A
Will not start as i am not sure if i have the correct firing order for the spark plugs.it tries to turn over, but it appears to backfire,and just runs the battery down
if your standing in front of the car and looking at the coil pack the order across from left to right will be 1 4 6 3 2 5 . The front bank of plugs are odd 1 3 5 the back bank are even 2 4 6.
I hope this helps.
Aug 27, 2010 | 2002 Chevrolet Malibu
9999555533331111 out of these numbers any 6 numbers total is 21? how
this would be explained on the basis of two FACTS below.......
sum of two odd numbers are always even and
sum of to even numbers are also always even
then how 6 odd numbers (consider 3 pairs, 9 5 3 1 being odd numbers) can make an odd number 21..!!
SO SIMPLE
Make your basics strong...
Aug 14, 2010 | Computers & Internet
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Feb 12, 2010 | 2007 Dodge Ram Truck
96 blazer dies at during braking with less the 1/4 tank of fuel or will refuse to start while parked on a nose low incline
possible fuel pump and/or incorrect fuel reading...these senders in tank can give false reading to gauge.key on-engine off runs pump for 3 seconds...listen to the pump in a quiet place like a closed garage and alot of times these pumps sound odd when failing like a louder whining noise than normal. turning the key off for 5 secs will reset and run the pump once again when you turn key on but do not crank. fuel pump is fairly common failed item for this make and model.Replacing sender while servicing pump is reguarly done as well.
Jul 09, 2009 | 1996 Chevrolet Blazer
Whirlpool GU980 gold fills runs for 5 seconds then drains
Appears that the controller has gone ballistic and is now doing its own thing. That part may need replacement. Search Over 2 1 Million Appliance Parts
Sep 05, 2017 | Whirlpool Dishwashers
GE Profile DPVH880EJMG Electric Dryer Logo
50 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
