Question about Goodman CLQ36AR49 Air Conditioner
No suction pressure at condenser test port
I changed out r22 condenser unit , I installed a used working trane Xl-13 . I have 150 psi on high side port and little to zero pressure on low side test port. Is it possible that trash could be against low side service valve. Or incompatibility with air handler and condenser unit? It was around 70 degrees outside
    Genius:
  • Goodman Master
  • 1,363 Answers
I would suspect the valve on suction side not open. if the other system failed on a burn out you could have a blocked dryer or orfice at coil.
Posted on Aug 09, 2015
  • 14 Answers
SOURCE: 5 year old Goodman CKJ48-1A Condenser Unit
do what they said also when those pressures equalizing it might be your compressor going out
Posted on Oct 16, 2008
  • 588 Answers
SOURCE: I am working on a
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Posted on Aug 18, 2010
  • 157 Answers
SOURCE: I had my GSC13048AG aicr
I believe He is talking about the suction pressure, not head pressure which runs much higher, he's likely correct but this symptom could be due to several things, discuss it thoroughly with your service provider
Posted on Jul 26, 2011
SOURCE: what should the suction and high side pressure be
r22 3ton what should high low side pressures be
Posted on Aug 04, 2011
SOURCE: hello, my HVAC is constantly
I'm new at this and I can't tell how old the post is but I'll contribute anyway.
You probably have fixed the problem by now. I wonder what part of the system is freezing up. I don't have a lot of experience but I know you can get frost where there is a restriction in the freon. If the freon line filter near the outside unit has frost on the house side the filter is partially plugged. I have also seen fost on the evaporator (attic "A" coil) when there is a shortage of return air flow. You could have a plugged filter or colapsed return duct, or even an "A" coil with a lot of dust covering and plugging the fins. I guess restrictions in your room air supply registers could cause the problem too. Maybe you have most of the vents closed off to save energy. Just some possibilities.
Posted on Oct 31, 2012
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
R22 need diagnosis please
It could mean you are overcharged and that somone tried to resolve the real problem by adding refrigerant (R22).
Dec 11, 2013 | Heating & Cooling
I want to recharge the a/c of my 2004 Rainier, but do not know where the low pressure port is and the caps are not marked with L or H. Help! Thank you.
The good news is a that vehicle has R134A which means the quick release from your refill can will only fit the low pressure side which is normally a little higher than the High. Unlike the old R22 systems the Low and High pressure connections are slightly different in size.
Apr 02, 2011 | 2004 Buick Rainier
I use to do a/c work many years ago, forgot a few things. like what the pressure should be on the low side, 88% out side 77% inside do you have an approx. psi. using r22
The back pressure on the suction side should be around 65-70 psi with R-22. Make sure the condenser coil is clean and that the condenser fan is working ok.
Also be sure the indoor filter is clean and that fan is running on high speed.
Jul 22, 2010 | Whirlwind FH-778 Air Conditioner
How do you check to see if the high side is leaking back into the low side on a scroll compressor suction pressure is 90psi R-22 suction line is warm but not hot
90 psi is very high for R22....low for R410 refrigerant. If leaking by the head pressure and suction pressure will be close to to the same reading
May 10, 2010 | Heating & Cooling
HOW TO RECHARGE SPLIT TYPE AIR CONDITIONER WITH USING r22
check cooling coil(in door unit)if there ice buil up then feel air vent if no air mean your fin block aready need to clean / air vent ok meant there have a leak .you need r22 test gauge and hose,reamer,tube cutter and flaring kit. 1)check suction pressure(big tube at out door unit) remove 2 way cap and 3 way cap valve then connect blue hose at service port 3 way valve (port locate at left or right depent on manufacturer) you will get pressure about 40-45 psi(air cond is running) then use a allen key(hexagonal wrench) to close 2 way valve(small tube or gas discharge side) wait 1-2 minute then close 3 way valve (suction tube or big tube) IMMEDIATELY SHUT OFF AIRCOND AND PLUG OUT POWER CORD (you need 2 person one at in door unit and the other at out door unit). this method is to keep remaining gas inside the compresser.Then leak check ,open 2 way valve about 90 degree hold it for 10 minute then close it .MEASURE THE PRESSURE keeep it for 5-10 minute. If the pressure indicate not same during the first time measured it meant there have a leakage, for air cond 1- 5 year the leakage will happen at the copper tubing connection and improper flaring .Then U need to clean in door and out door unit ,used a spanner or wrench to losen the copper FLARE NUT at out door unit and in door unit( inside insulation) then use pvc tape to cover all copper pipe/tube hole to prevent dirt go inside tube/pipe. Then lift up out door unit and used coil cleanner ditergent wait 5 minute then flush with water. Remove indoor front panel then disconnect out door unit cable at front panel in door unit then lift up indoor unit to disangage the hook and pull out the indoor unit, then clean the cooling coil ,cover electrical part with plastic .last step u need to cut (used cooper cutter)the copper pipe/tube FLARE NUT connection low side(big tube) and high side(small tube) in door connection and out door connection .Then u need to remove the burr from cut edge using reamer make sure metal powder not goes in Then make a flare after inserting FLARE NUT onto the copper pipes Then U can install back the unit check the low side pressure if the pressure 55-67 psi no need to charge
Jul 03, 2009 | Heating & Cooling
Discharge pressure reading 150 psi and suction reading 70 psi what could cause this problem on a heat pump? this is a r22 system
need to know the room temp and out side temp but the expansion valve could be sticking open or the compressor could have bad valves hook up hi side hose to true high side port and shut the liquid valve off in the line set in cooling mode make call for unit to come on and as it pumps down the hi side should go up if not the comp is week but if room temp is 85 or higher and out side about same still low on charge the suction will fall when room cools and the expansion valve quits flooding the coil
May 10, 2009 | Heating & Cooling
How to hookup refrigerent gauges to central air?
Outside in the condensing unit you'll see the two copper pipes coming from the valves in the condensing unit. atach the hose from the high pressure gauge to the port in the smaller copper pipe (liquid line) and the other hose to the port of the other line (suction line) in there you check the low pressure (68psi) and if is low you can rechrge it, in the high side you should have no much more than 250psi .This pressures are for R22.
Apr 25, 2009 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
61 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
