Question about Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Motor and light don't work
Have power to fan nothing works
Blower fan not working?
with the fan turned on locate the blower motor and tap it if it starts then the motor needs replacing. you can also check for power at the motor with a test light if you have power chances are good the motor again is bad. if you don`t have power its probably the blower motor resistor which is a common problem. follow the wires back from the motor it will lead you to the resistor.
Aug 24, 2014 | Cars & Trucks
GE Adora microwave worked 20 minutes ago. Now, totally dead. The lights, fans, turntable motor, microwave cooking elements, nothing.. works. AC power to the outlet is just fine.
Sometimes if a lot of steam has been produced while cooking, water may collect under the turntable plate and run down the spindle into the turntable motor. This can short circuit the motor and it will take the fuse out with it.
The fuse is usually housed in a plastic tubular case about 2inches long. Split the tube apart and replace the fuse if necessary (it's something silly like about 7000 volts). Switch on and check to see if anything else is not working like the turntable, lights, or fan etc and replace as necessary.
Feb 16, 2014 | General Electric DVM1950SRSS 505 Adora...
The heat in my 96 mazda protege dosn't work
With the ignition and fan switches turned on check for power at fan motor.If you have power at the motor then wiggle and maybe pull on the blower motor resistor and if fan comes on just fix the connection.But when you check for power at the blower motor and don't have power then check the fan relay if it does'nt click when you turn it on then its faulty.
Oct 29, 2012 | 1996 Mazda Protege
Nordictrack auidostridder 800 elliptical screen dead
Chad Gilbert--
I'm having the same problem with my Audiostrider 800. Fan works, screen and soft buttons do nothing.
I dont mean to sound dumb, but where are these motor brushes? Are they attached to the resistance motor or somewhere else? What exactly am I looking for?
Any help would be greatly appreciated!!
Aug 11, 2012 | Nordic Track Nordictrack Audiostrider 800...
Stopped working. light comes on
The fan motor is bad, it will give you a power light but nothing else. To be quite honest with you it is cheaper to replace the heater then to go thru the agrivation of replacing the fan motor. Sorry this is probably not the answer you were hoping for.
Dec 10, 2010 | DeLonghi SafeHeat Heater
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Jul 16, 2008 | Casablanca Fan 3245T Ceiling
Fan will not run, but light works
Could be the switch. More likely to be a speed controler or the windings of the fan motor itself.
Turn all power off, and remove it, then check the switch first, the windings next, and look at the controller 3rd.
Apr 16, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Emachine 5210 not working
how old is your emachine?? is your display in condition?? if so, your smps might've worn out.. this is what happens when the display is proper but u still don see anything on the screen..
Mar 12, 2008 | E-Machines eMachines Desktop PC
Heritage (5BFW52NK4KG) 52'' Ceiling Fan Logo
54 people viewed this question
Top Heritage Dryers Experts
roeb
Michael Galve
Michael Galve
Ottoniel
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
