Question about GE Profile DPVH880EJMG Electric Dryer
Runs for 10 seconds and turns off - GE Profile DPVH880EJMG Electric Dryer
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Just dies after about 5-10 seconds
this may be due to the fault in the pump check that
May 27, 2008 | 2002 Volkswagen Cabrio
BHG stand mixer only runs 10 seconds
It sounds like a thermal fuse (circuit breaker). The fuse is tripping nice it gets warm (or the mixer is stresses). These mixers don't have ball bearings, they have bushings that are oil impregnated from the factory. The oil eventually dries out or hardens if flour or other contaminants get in there. The bearings could be siezed to some degree and make the motor difficult to turn, and cause the fuse to trip.
Make sure you can easily turn it by hand (when unplugged). If you cannot, you will need to fix the cause. Or replace it if cheap enough.
Sep 04, 2014 | Food Mixers
Brand new Simer pump Model 2330-03 runs 10 seconds shuts off, turns back on, runs 10 seconds shuts off, etc., etc. Why is this happening?
Sounds like a faulty switch on the float. Try to hold the switch up by hand and see if it stays running, if so you may need to lube the switch. If not then it sounds like a manufacturer defect and needs to be returned.
May 07, 2011 | Simer 1/6 Hp Submersible Utility Pump
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Nov 16, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Side by side not cold
compressor overheated or stuck. also check starter relay...maybe broke.
if ever thing is alright,
let it stand for about 4 hours unplugged to cool the compressor.
plug it after 4 hours and if the compressor would still run for 10 seconds, then you have a faulty compressor.
tnx 4 using fixya,
drcool
Sep 09, 2008 | Kenmore Refrigerators
AKAI LCT2785TA TV does not turn on
look closely at the electrolytic capacitors in the power supply. If you see any with the tops bulging out, replace them. Especially the 1000mfd caps labeled EC9, EC10, EC18, EC19, EC20
Jun 21, 2008 | Televison & Video
GE Profile DPVH880EJMG Electric Dryer Logo
47 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
